Repeater mode does not work on GL-B3000
Hi team,
I tried connecting serveral times but when you try connect the GL-B3000 (Marble) with any router it tell me connecting and is stuck there. I have upgraded to version 4.5.22 and still the issue persists. Any solution ?
  1. Please try to press and hold the reset button for 10 seconds to restore the factory settings and then test again
  2. Use V4.7.2 beta firmware, this version optimizes the repeater function.
    GL.iNet download center
Dear Ale,
Thanks for the solution, I flashed using the beta version and I confirm it works. But there is another issue, it takes multiple attempts to connect to the main router after the GL-B3000 is restarted. This was not what I expected from a router manufacturer. GliNet can't get a product right, then why manufacture and sell it ?
We sincerely apologize for the inconvenience you've experienced with the GL - B3000's connection after reboot.
After thorough analysis, we've found that such connection issues after restart are occasional and not inherent product defects.
It may be related to the parent network and external interference.
How long do you wait?
Do you have the log?
I have upgraded to v4.7.2 beta firmware on the Marble and to 4.7 on the Flint 2. But still unable to use the Marble as a repeater even after multiple tries and reboots. Any guide on how to do this?
Can Marble search for Flint 2's WiFi in the admin panel?
Is it not possible to connect Marble to any WiFi as a repeater? Such as phone hotspot.
Please export the log.
I do see the SSID from the Flint 2. Both the 5GHz and the 2.4Ghz. I have tried connecting to a different SSID and still the same result.
From the exported logs I see
Wed Jul 16 21:05:30 2025 daemon.info gl-repeater[1906]: (repeater.lua: 49) skip disabled bss 94:.....:30
Wed Jul 16 21:05:30 2025 daemon.info gl-repeater[1906]: (repeater.lua:1011) not found matched bss for MyWirelessNetwork
I have removed the MAC address above.
This is what I see every time it fails to connect. I am still trying to figure out where that MAC address is from but have no idea.
If you want me to export the full logs, please let me know if it is safe to share here or if I should share via email. thanks
I sent you a PM. Please check.
