My GL-inet Beryl is connected to my apartment wi-fi and set to repeater mode. But every few days it disconnects and takes a while to get reconnected. When I manually disconnect and reconnect in the admin panel, it connects back fine. I had another Beryl and I didn’t have issues like that before. Could this be device fault, or anything I can do?
Can you let me know how long?
When this happens, can you login the router and get the logs immediatelly?
About what while do we talk? 10 minutes? 3 hours? More?
That first sentence hurt my brain.
I’d say 10-20 minutes. It could be longer because when I’m in the house I just manually reconnect. I’ll try to get the logs next time it happens.
probably 10-20 minutes
What Wi-Fi channel do you use?
@admon @alzhao
Here is my Wi-Fi settings. It says channel can’t be modified when repeater is enabled.
Also it crashed again, I wasn’t able to get the logs immediately but ~10 min after. Does this mean anything to you? (It is a part of it)
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.853526] PrintSrCmd:
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.853526] u1CmdSubId = 5, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.853526] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.868049] PrintSrCmd:
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.868049] u1CmdSubId = 3, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.868049] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 1
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.882573] PrintSrCmd:
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.882573] u1CmdSubId = 23, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.882573] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.897176] PrintSrCmd:
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.897176] u1CmdSubId = 31, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.897176] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.911774] PrintSrCmd:
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.911774] u1CmdSubId = 33, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.911774] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Fri Apr 26 19:36:55 2024 kern.err kernel: [1234017.926405] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234017.937535] 7981@C03L3,MtCmdTxPwrShowInfo() 13746: ucTxPowerInfoCatg: 2, BandIdx: 0
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234017.945456] 7981@C03L3,MtCmdTxPwrShowInfo() 13775: (ret = 0)
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234017.945569] [mtf_txpower_all_rate_info] band_idx:0 pwr:37 ChBand:2G ePAGain:0
Fri Apr 26 19:36:55 2024 kern.info kernel: [1234017.951291] extif_set_dev(ra1)
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234017.959343] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Fri Apr 26 19:36:55 2024 kern.info kernel: [1234017.961794] mtk_ppe_dev_register_hook : ineterface ra1 register (2)
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234017.970210] 7981@C13L2,Set_DisConnectAllSta_Proc() 22426: Send DeAuth (Reason=2) to 10:2c:6b:56:43:36
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234017.975155] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234017.996065] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.001345] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.009017] 7981@C08L2,ap_peer_disassoc_action() 3479: ASSOC - 1 receive DIS-ASSOC request
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.017510] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.017521] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.031018] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:10:2c:6b:56:43:36
Fri Apr 26 19:36:55 2024 kern.err kernel: [1234018.038811] 7981@C12L1,rt28xx_ap_ioctl() 893: interface is down, cmd [8be2] return!!!
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.052138] 7981@C08L2,mbss_virtual_if_open() 134: ===> rax1
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.058098] 7981@C01L2,RTMP_COM_IoctlHandle() 1523: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.066375] 7981@C01L2,RTMP_COM_IoctlHandle() 1500: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.074563] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 3
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.080301] 7981@C18L3,BuildChannelList() 484:
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.085064] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(40), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.096881] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(40), cen_ch_1(42), cen_ch_2(0),ext_cha(3)!
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.108707] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(40), cen_ch_1(42), cen_ch_2(0)!
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.119986] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=40, ctrl_ch2=0, cent_ch=42 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.133260] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=40, ctrl_ch2=0, cent_ch=42, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Fri Apr 26 19:36:55 2024 kern.err kernel: [1234018.147238] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.158614] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.166823] wdev_attr_update(): wdevId3 = 96:83:c4:3d:d3:ca
Fri Apr 26 19:36:55 2024 kern.err kernel: [1234018.172594] WiFi@C12L1,wifi_sys_open() 907: wifi_sys_open():band1 group_idx[3]=25, bw_grp=16 omac=17
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.181941] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=3
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.188963] 7981@C02L2,AsicRadioOnOffCtrl() 2340: DbdcIdx=1 RadioOn
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.195559] 7981@C00L2,ApAutoChannelAtBootUp() 333: ----------------->
Fri Apr 26 19:36:55 2024 kern.err kernel: [1234018.202398] 7981@C03L1,MtCmdSetMacTxRx() 10246: (ret = 0)
Fri Apr 26 19:36:55 2024 kern.err kernel: [1234018.208089] 7981@C03L1,MtCmdSetMacTxRx() 10246: (ret = 0)
Fri Apr 26 19:36:55 2024 kern.err kernel: [1234018.213668] 7981@C00L1,ApAutoChannelAtBootUp() 491: zero-wait DFS is not enabled
Fri Apr 26 19:36:55 2024 kern.err kernel: [1234018.221246] 7981@C08L1,ap_run_at_boot() 623: e[41m ACS is disable !!e[m
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.228234] 7981@C08L2,APStartUpForMbss() 983: ===>(caller:ap_inf_open+0x144/0x4e0 [mt_wifi]), mbss_idx:3, CfgMode:177
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.239164] 7981@C15L2,APPMFInit() 121: [PMF] Security is not WPA2/WPA2PSK AES
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.246572] 7981@C15L2,APPMFInit() 133: [PMF] apidx=3, MFPC=0, MFPR=0, SHA256=0
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.254058] 7981@C18L3,BuildChannelList() 484:
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.258982] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.266795] WiFi@C08L2,ap_link_up() 7143: (caller:wdev_do_linkup+0x20/0x38 [mt_wifi]), wdev(3)
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.275620] 7981@C01L3,wifi_sys_linkup() 1231: wdev idx = 3
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.281577] 7981@C00L3,wtc_acquire_groupkey_wcid() 84: Found a non-occupied wtbl_idx:284 for WDEV_TYPE:1
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.281577] LinkToOmacIdx = 11, LinkToWdevType = 1
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.296443] 7981@C08L3,hw_ctrl_flow_v2_link_up() 72: wdev_idx=3
Fri Apr 26 19:36:55 2024 kern.notice kernel: [1234018.306954] 7981@C08L3,UpdateBeaconHandler() 1911: BCN_UPDATE_INIT, OmacIdx = 11 (rax1)
Fri Apr 26 19:36:55 2024 kern.warn kernel: [1234018.315132] 7981@C08L2,bcn_buf_init() 170: BcnPkt is allocated!, bcn offload=1
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.335970] PrintSrCmd:
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.335970] u1CmdSubId = 1, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.335970] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 1
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.350502] PrintSrCmd:
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.350502] u1CmdSubId = 5, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.350502] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.365011] PrintSrCmd:
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.365011] u1CmdSubId = 3, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.365011] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 1
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.379532] PrintSrCmd:
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.379532] u1CmdSubId = 23, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.379532] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.394134] PrintSrCmd:
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.394134] u1CmdSubId = 31, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
Fri Apr 26 19:36:55 2024 kern.debug kernel: [1234018.394134] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
Fri Apr 26 19:36:56 2024 kern.debug kernel: [1234018.408738] PrintSrCmd:
Fri Apr 26 19:36:56 2024 kern.debug kernel: [1234018.408738] u1CmdSubId = 33, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
I’ve also attached logread.tar
Thanks
logread.tar (229 KB)
The interruptions can be associated with the use of a DFS-channel. The access-point has to scan these frequencies in regular intervals. This can leed to regular interruptions of the communication between the repeater and the access-point.
That was exactly what I thought.
Afaik the repeater will stop trying to connect after a few failed connections. This could lead to this issue since because of DFS the main router isn’t available for 5-10 minutes.
@alzhao Could I be right with that?
I had seen this log, but it is incomplete.
Could you export a full log?
I’ve attached the logread.tar file and that’s all I have. I think it doesn’t have the logs when it was disconnected. But about an hour later it disconnected again and I was able to get the logs almost right away. This time it reconnected quickly but I think it’s relevant:
Fri Apr 26 20:31:45 2024 kern.err kernel: [1237307.425156] 7981@C15L1,check_rx_pkt_pn_allowed() 745: BC, check_rx_pkt_pn_allowed (4)(2) Reject: come-in the 30917 and now is 30920
Fri Apr 26 20:31:45 2024 kern.err kernel: [1237307.437164] 7981@C15L1,check_rx_pkt_pn_allowed() 745: BC, check_rx_pkt_pn_allowed (4)(2) Reject: come-in the 30918 and now is 30920
Fri Apr 26 20:31:45 2024 kern.err kernel: [1237307.449155] 7981@C15L1,check_rx_pkt_pn_allowed() 745: BC, check_rx_pkt_pn_allowed (4)(2) Reject: come-in the 30919 and now is 30920
Fri Apr 26 20:37:43 2024 kern.err kernel: [1237665.427899] 7981@C09L1,ApCliPeerCsaAction() 944: Channel Change due to csa
Fri Apr 26 20:37:43 2024 kern.notice kernel: [1237665.435160] 7981@C23L3,TakeChannelOpCharge() 1109: caller:ApCliPeerCsaAction+0x120/0x380 [mt_wifi]. TakeCharge succeed!
Fri Apr 26 20:37:43 2024 kern.notice kernel: [1237665.435160] 7981@C23L3,rtmp_set_channel() 2815: (caller:ApCliPeerCsaAction+0x204/0x380 [mt_wifi]), Channel(108), quick_ch_change:1.
Fri Apr 26 20:37:43 2024 kern.notice kernel: [1237665.458460] 7981@C23L3,zero_wait_dfs_update_ch() 815: ch 108, outband ch 0, ch_stat 0, pDfsParam->band_ch[0]=0, pDfsParam->band_ch[1]=124
Fri Apr 26 20:37:43 2024 kern.notice kernel: [1237665.471179] 7981@C23L3,perform_channel_change() 2510: (caller:rtmp_set_channel+0x270/0x538 [mt_wifi]), Channel(108), quick_ch_change:1.
Fri Apr 26 20:37:43 2024 kern.notice kernel: [1237665.483564] 7981@C23L3,HcUpdateCsaCntByChannel() 596: Channel(124).
Fri Apr 26 20:37:44 2024 kern.notice kernel: [1237665.490018] 7981@C00L3,HcUpdateCsaCntByChannel() 648: CSAEventTimer start(wdev_counter=1)
Fri Apr 26 20:37:44 2024 kern.notice kernel: [1237665.498386] 7981@C23L3,perform_channel_change() 2774: (Channel=108)
Fri Apr 26 20:37:44 2024 kern.notice kernel: [1237665.504854] 7981@C23L3,DfsBuildChannelList() 3708: Done
Fri Apr 26 20:37:44 2024 kern.notice kernel: [1237665.510255] 7981@C23L3,zero_wait_dfs_switch_ch() 925: outband ch 0, ch_stat 0
Fri Apr 26 20:37:44 2024 kern.notice kernel: [1237665.517574] 7981@C23L3,zero_wait_dfs_switch_ch() 932: bDedicatedZeroWaitDefault == 0
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.532420] 7981@C14L3,ExtEventCswNotifyHandler() 2373: wdev:rax0, wdev->csa_count:0
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.540341] 7981@C23L3,ChannelSwitchingCountDownProc() 468: CSAEventTimer normal end!!
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.548527] 7981@C23L3,Dot11HCntDownTimeoutAction() 566: [RDM]^[[1;33m Change to RD_SILENCE_MODE^[[m
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.557663] 7981@C23L3,Dot11HCntDownTimeoutAction() 577: wdev name(rax0), quick 1 ,ch 108
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.566012] 7981@C23L3,Dot11HCntDownTimeoutAction() 580: cacreq 0
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.572278] 7981@C13L3,Dot11HCntDownTimeoutAction() 598: CSA done and Disable Beacon: rax0
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.580943] 7981@C23L3,ap_phy_rrm_init_byRf() 1891: (caller:Dot11HCntDownTimeoutAction+0x27c/0xa40 [mt_wifi]), wdev_idx:2.
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.580985] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:3d:d3:ca), Reason 0x10
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.592360] 7981@C08L3,MacTableResetNonMapWdev() 2078: (caller:ap_phy_rrm_init_byRf+0x214/0x650 [mt_wifi]), wdev_idx:2.
Fri Apr 26 20:37:45 2024 kern.err kernel: [1237666.601196] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Fri Apr 26 20:37:45 2024 kern.debug kernel: [1237666.619267] Send DeAuth (Reason=2) to dc:e5:5b:42:53:a4
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.629769] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.636099] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.643357] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:dc:e5:5b:42:53:a4
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.643465] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:3d:d3:ca), Reason 0x10
Fri Apr 26 20:37:45 2024 kern.debug kernel: [1237666.650711] Send DeAuth (Reason=2) to 06:ee:ef:f3:c6:ac
Fri Apr 26 20:37:45 2024 kern.err kernel: [1237666.659622] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.670077] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.681021] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.688266] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:06:ee:ef:f3:c6:ac
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.688508] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:3d:d3:ca), Reason 0x10
Fri Apr 26 20:37:45 2024 kern.debug kernel: [1237666.695625] Send DeAuth (Reason=2) to 1c:53:f9:35:ad:63
Fri Apr 26 20:37:45 2024 kern.err kernel: [1237666.704524] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.722075] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.728416] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.735646] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:1c:53:f9:35:ad:63
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.735743] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:3d:d3:ca), Reason 0x10
Fri Apr 26 20:37:45 2024 kern.debug kernel: [1237666.742999] Send DeAuth (Reason=2) to da:1e:59:83:e1:ee
Fri Apr 26 20:37:45 2024 kern.err kernel: [1237666.751905] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.762374] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.770654] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.778133] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:da:1e:59:83:e1:ee
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.778175] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:3d:d3:ca), Reason 0x10
Fri Apr 26 20:37:45 2024 kern.err kernel: [1237666.794393] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.795514] 7981@C13L3,ap_phy_rrm_init_byRf() 2004: Wlan_operate_init and switch channel for : rax0
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.810663] 7981@C23L3,RadarStateCheck() 244: Zero Wait State: 0
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.816850] 7981@C23L3,RadarStateCheck() 268: ^[[1;33m RD_SILENCE_MODE ^[[m
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.823900] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(108), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.835824] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(108), cen_ch_1(106), cen_ch_2(0),ext_cha(1)!
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.847829] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(108), cen_ch_1(106), cen_ch_2(0)!
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.859220] 7981@C23L3,DfsCacNormalStart() 3575: [RDM] CAC 65 seconds start . Disable MAC TX
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.867950] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=108, ctrl_ch2=0, cent_ch=106 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.894612] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=108, ctrl_ch2=0, cent_ch=106, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Fri Apr 26 20:37:45 2024 kern.err kernel: [1237666.908774] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237666.920184] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.928564] 7981@C23L3,ap_phy_rrm_init_byRf() 2018: Updated RaBf info bw by wdev ~~~
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.936541] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.945068] 7981@C08L3,UpdateBeaconHandler() 1936: Band1 BcnInitedRnd = 32678
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.952482] 7981@C13L3,ap_phy_rrm_init_byRf() 2004: Wlan_operate_init and switch channel for : apclix0
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.961984] 7981@C23L3,RadarStateCheck() 244: Zero Wait State: 0
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.968171] 7981@C23L3,RadarStateCheck() 268: ^[[1;33m RD_SILENCE_MODE ^[[m
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.975229] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(108), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.987149] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(108), cen_ch_1(106), cen_ch_2(0),ext_cha(1)!
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237666.999151] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(108), cen_ch_1(106), cen_ch_2(0)!
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237667.010549] 7981@C23L3,DfsCacNormalStart() 3575: [RDM] CAC 65 seconds start . Disable MAC TX
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237667.019239] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=108, ctrl_ch2=0, cent_ch=106 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237667.032694] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=108, ctrl_ch2=0, cent_ch=106, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Fri Apr 26 20:37:45 2024 kern.err kernel: [1237667.046826] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Fri Apr 26 20:37:45 2024 kern.warn kernel: [1237667.058181] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237667.066602] 7981@C23L3,ap_phy_rrm_init_byRf() 2018: Updated RaBf info bw by wdev ~~~
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237667.074579] 7981@C13L3,Dot11HCntDownTimeoutAction() 669: channel switch diff: 493 msec
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237667.082981] 7981@C23L3,DfsBuildChannelList() 3708: Done
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237667.088408] 7981@C23L3,zero_wait_dfs_switch_ch() 925: outband ch 0, ch_stat 0
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237667.095714] 7981@C23L3,zero_wait_dfs_switch_ch() 932: bDedicatedZeroWaitDefault == 0
Fri Apr 26 20:37:45 2024 kern.notice kernel: [1237667.103942] 7981@C23L3,Dot11HCntDownTimeoutAction() 764: cac not req 0
Fri Apr 26 20:37:57 2024 kern.notice kernel: [1237667.110661] 7981@C23L3,ReleaseChannelOpChargeForCurrentOwner() 1456: the ChOpCharge of owner=6 is released now!!
Fri Apr 26 20:37:57 2024 kern.warn kernel: [1237679.422564] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Apr 26 20:37:57 2024 kern.notice kernel: [1237679.441864] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Apr 26 20:37:57 2024 kern.warn kernel: [1237679.449105] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:08:8e:90:38:f9:e1
Fri Apr 26 20:37:57 2024 kern.notice kernel: [1237679.456553] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-52) from 08:8e:90:38:f9:e1, reason=1
Fri Apr 26 20:38:44 2024 kern.notice kernel: [1237726.105783] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]2a:ce:7a:31:00:b0
Fri Apr 26 20:38:44 2024 kern.debug kernel: [1237726.118871] entrytb_aid_aquire(): found non-occupied aid:5, allocated from:4
Fri Apr 26 20:38:44 2024 kern.warn kernel: [1237726.126107] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:2a:ce:7a:31:00:b0
Fri Apr 26 20:38:44 2024 kern.notice kernel: [1237726.137085] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - 2a:ce:7a:31:00:b0
Fri Apr 26 20:38:44 2024 kern.notice kernel: [1237726.146522] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)…
Fri Apr 26 20:38:44 2024 kern.notice kernel: [1237726.155809] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Apr 26 20:38:44 2024 kern.notice kernel: [1237726.162030] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Apr 26 20:38:44 2024 kern.notice kernel: [1237726.283046] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Fri Apr 26 20:38:44 2024 kern.notice kernel: [1237726.294634] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Fri Apr 26 20:38:44 2024 kern.notice kernel: [1237726.301572] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Fri Apr 26 20:38:44 2024 kern.notice kernel: [1237726.308540] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Fri Apr 26 20:38:44 2024 kern.warn kernel: [1237726.320315] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=2 from 2a:ce:7a:31:00:b0
Fri Apr 26 20:38:49 2024 daemon.info dnsmasq-dhcp[4552]: DHCPDISCOVER(br-lan) 2a:ce:7a:31:00:b0
Fri Apr 26 20:38:49 2024 daemon.info dnsmasq-dhcp[4552]: DHCPOFFER(br-lan) 192.168.8.205 2a:ce:7a:31:00:b0
Fri Apr 26 20:38:49 2024 daemon.info dnsmasq-dhcp[4552]: DHCPREQUEST(br-lan) 192.168.8.205 2a:ce:7a:31:00:b0
Fri Apr 26 20:38:49 2024 daemon.info dnsmasq-dhcp[4552]: DHCPACK(br-lan) 192.168.8.205 2a:ce:7a:31:00:b0 Pixel-7
Fri Apr 26 20:38:54 2024 kern.notice kernel: [1237735.712308] 7981@C23L3,DfsCacEndUpdate() 3142: [RDM] CAC end. Enable MAC TX.
Fri Apr 26 20:39:02 2024 kern.notice kernel: [1237743.762391] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]dc:e5:5b:42:53:a4
Fri Apr 26 20:39:02 2024 kern.debug kernel: [1237743.775483] entrytb_aid_aquire(): found non-occupied aid:8, allocated from:4
Fri Apr 26 20:39:02 2024 kern.warn kernel: [1237743.782716] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:dc:e5:5b:42:53:a4
Fri Apr 26 20:39:02 2024 kern.notice kernel: [1237743.791132] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - dc:e5:5b:42:53:a4
Fri Apr 26 20:39:02 2024 kern.notice kernel: [1237743.800576] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)…
Fri Apr 26 20:39:02 2024 kern.notice kernel: [1237743.809853] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Fri Apr 26 20:39:02 2024 kern.notice kernel: [1237743.816051] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Fri Apr 26 20:39:02 2024 kern.notice kernel: [1237743.938583] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Fri Apr 26 20:39:02 2024 kern.notice kernel: [1237743.945379] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Fri Apr 26 20:39:02 2024 kern.notice kernel: [1237743.952282] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Fri Apr 26 20:39:02 2024 kern.notice kernel: [1237743.959155] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Fri Apr 26 20:39:02 2024 daemon.info dnsmasq-dhcp[4552]: DHCPDISCOVER(br-lan) 192.168.8.105 dc:e5:5b:42:53:a4
Fri Apr 26 20:39:02 2024 daemon.info dnsmasq-dhcp[4552]: DHCPOFFER(br-lan) 192.168.8.105 dc:e5:5b:42:53:a4
Fri Apr 26 20:39:02 2024 kern.warn kernel: [1237743.970904] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=5 from dc:e5:5b:42:53:a4
Fri Apr 26 20:39:03 2024 kern.notice kernel: [1237744.742268] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]1c:53:f9:35:ad:63
Fri Apr 26 20:39:03 2024 kern.debug kernel: [1237744.755368] entrytb_aid_aquire(): found non-occupied aid:9, allocated from:4
Fri Apr 26 20:39:03 2024 kern.warn kernel: [1237744.762607] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:1c:53:f9:35:ad:63
Fri Apr 26 20:39:03 2024 kern.notice kernel: [1237744.772117] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - 1c:53:f9:35:ad:63
I think disconnected again at 20:37, when the log says “Channel Change due to csa”, but the timing may be a bit off. I’ll upload the new logread.tar
logread.tar (230 KB)
Afaik repeating will copy all settings from the main network, you can’t change them.
What I do with my Slate plus when connect it to a hotel-WLAN: I connect the hotel-WLAN on 2.4GHz and fix the Slate to 2.4GHz.
For my internal WLAN I use channel 161 (SRD) with 80MHz bandwidth.
Until now this configuration worked in all hotels, whether they have password or captive portals.
Edit: I switch the Slate to “router”-mode when I use it in a hotel.
I do similar but I generally reverse the channels. I try to use the 5ghz for the hotel connection if available. I generally connect my clients to the 2.4ghz channel for the travel router. But if it is slow, I try both ways and see what performs the best if I am going to be there a few days. Sometimes it is just easier and faster to tether my phone.
I’ve changed it to connect to 2.4GHz non-DFS channel for now, I’ll see how it performs. Thanks to everyone who replied!
2.4ghz does not include any DFS channels btw. That is a 5ghz problem.
