"Repeater (STA) is disabled" after a while
This is my general config:
Router connected as a client to a WiFi network (2.4G)
Router broadcasts SSID as WiFi server (2.4G)
This is the issue:
After a while, the router disconnects from the WiFi network and “Repeater (STA) is disabled”. It does not automatically reconnect, I have to click on “Connect”
Screenshot 2024-02-29 at 4.37.27 PM
I have several routers that seem to exhibit the same behaviour.
Router: GL-AR750S, v4.3.10
Router: A1300, v4.5.0
This seems to be a bug, is there a workaround for it?
Thanks
Can you pls export the log?
The repeater will be disabled if there is many failed tries. So hopefully the logs shows the reason.
This has been a long and ongoing bug. See my older threads. No solution has been forthcoming.
