Basic user here. I have the Slate AX. I was connected to my AT&T hotspot, clicked on repeater and now cannot get to the GLi router gateway any longer.
Any assistance is welcome. Thank you
I believe that you are unable to access the UI when in repeater mode. However, I have discovered that if you have GoodCloud enabled, you can access the UI that way. If you hold reset for 4 seconds, it will go back to regular router mode.
Correct, holding reset button for 4 sec until flashing pattern changes will cancel repeater mode.
Thank you for the replies. I did the reset and I was able to start over. Thank you
