Hi!
I need to replace console.gl-inet.com
with console.gl-inet.lan
as it makes some conflicts in my config. How to do this?
Hi!
First install faster grep
opkg update
opkg install grep
Once you have it installed, you can easily find the files that you need to change:
grep -s -irn “console.gl-inet” / | grep -v ‘overlay|rom’
Should be easy to change in luci. Supported replied via email.
What do you mean? I have nothing received
Received your email asking the exact questions and we replied.
Maybe you can check your email. We have no idea of what is the issue because it is sent using anonymous emails. But we replied and hope it go through.
Yeah. Found it. Thanks a lot!
It is not anonymous email
It is used to make it work with my self hosted (as there is some problems for delivery). BTW thanks!
