luben
Chinese developer Hackpascal released his alternative to standard routers uboot - Breed.
http://breed.hackpascal.net/
Is this bootloader compatible with GL-Inet6416?
If so witch version to be used because on site there are couple distro:
breed-ar9331-pisen.bin
breed-ar9331-hiwifi-hc6361.bin
breed-ar9331-mr12u.bin
breed-ar9331-wr710n.bin
breed-ar9331.bin
Thank you in advance!
alzhao
2
breed-ar9331-wr710n.bin should works. But I am not sure.
Be careful not to brick your device even this is the correct one.
luben
3
Hi alzhao,
Two more questions!
1.Which approach is better to be used during reflashing procedure?
-Using Uboot web recovery interface
-Manually from uboot recovery console follow example in your web site
http://www.gl-inet.com/docs/smartrouter/?diy_flashing.html
2.In case of successfully changing uboot with breed rest of the current openwrt image will stay in tact. Am I right?
Best
L.T
alzhao
4
Using the web interface is better.
After you replace the uboot, everything should works just fine.
