Replacement battery for GL-MiFi
where can i purchase a new battery for the GL-MIFI (Kanyo, 3.7V,
5000mAh)?
regards
Ronny Bachmann
Bangkok MBK :slight_smile:
Can you find something locally? The connector should be the same and the battery should be able to output 2A current continuously and 5A peak.
I got from IT Shop Schäpers UG two new batteries for 21,- USD incl. postage.
What about the newer 6-pin version? I’m not finding it anywhere on the English-language internet
This is a post 2 years ago. Now all mifi should use a 5-pin battery.
Ok, though I just need to replace the battery now that it’s swollen up. The device itself still works fine but only while plugged to external power.
Please send an email with your shipping address to our cs@gl-inet.com, we can help to check the availability of battery shipping.
Is it easy to install the battery? I hope instructions are included. I tried opening the box (4 screws) to have a look but the USB port and power knob and Eth ports perhaps need some trick or tools or force :grinning:
update: maybe it is not too hard to install, but rather hard to buy one… the ones I find for sale are priced by, say, 1000 pieces :upside_down_face: so maybe I should go hunt for one piece in a local chinatown :grinning: any suggestions welcome, I live in Belgium, Antwerp.
It is hard to find the same battery as the model is old.
Any new ideas where i can get a replacement battery for an old GL-Mifi ?
I don’t it is possible due to current logististics situations.
