I have an excellent and elegant router GL-MT300A
How do I change in it Serial Number and MAC-address?
Or destroy them?
I am not sure why you want to change or destroy them.
You can destroy the product but the data is stored in our database anyway.
Please, I will explain it willingly
I want to use your wonderful router for the Whonix deanimization system as a gateway, which is the first in the chain.
Unfortunately, the Serial Number of the router deanonymizes it and the entire system as a whole.
Therefore, it must either be changed or destroyed.
The MAC and SN, is static date stored on the router. It is the same as radio data, which you should not touch.
If you change firmware, the new firmware may not read the sn at all.
But most firmware need to read the mac address. The mac address can be changed in the firmware as well. it does not need to read the factory stored data.
Ok, thank you. So, what new firmware should I install so that it does not read and does not transmit s/n anywhere?
I am more interested in where do you find the s/n in the traffic? I couldnât identify it, by a short test.
Except Iâm in the admin panel, because it is not httpS://, for given reasons. And if the device itself wonât provide httpS:// only, I would not dig deeper in overcompensating âsecurityâ.
My Beryl does exactly what Iâve paid for. Providing a more secure âprivateâ network in my RV. I wouldnât send confidential government documents on this line, but it is enough for checking emails and do amazon shoping.
Firmware from OpenWrt is clean.
https://firmware-selector.openwrt.org/?version=SNAPSHOT&target=ramips%2Fmt7620&id=glinet_gl-mt300a
Yes, you are right, initially the serial number is not transmitted to the network.
But if we hypothetically assume that a malicious exploit has crept into the system, then it can do this
dirty trick.
Therefore, I want in advance to prevent such a dangerous possibility.
Thanks alzhao I will try to use this clean firmware.
alzhao ,
Iâm sorry, but I didnât find the firmware clean on this page âOpenWrt Firmware Selectorâ.
There are only SNAPSHOT and version numbers firmware.
How do I find clean firmware?
Have to clarify:
- OpenWrt has stable, snapshot etc.
- âcleanâ is only a term that we used. Before when there is no openwrt vanilla firmware for our routers, we will compile a firmware which is like openwrt vanilla firmware, i.e. contains as less software packages as possible. We call it âcleanâ.
So, all openwrt vanilla firmware is âcleanâ.
alzhao ,
If I understand you correctly, you will choose pure Openwrt with https://firmware-selector.openwrt.org , then add your useful improvements to it and then you put it on your https://forum.gl-inet.com ?
Yes you are right. We are based on openwrt.
