I have used Glinet B1300 router in more than 13000 points. and now the device is no longer produced (discontinue). so I want to replace it with a new device. does anyone know what device has the same firmware as Glinet B1300. because I use the api contained in firmware version 3.
Firmware 3.x is end-of-life, if you replace your B1300 with a new router now, you should switch to API 4.x
If there are requirements that are not fulfill by the 4.x you might share them here, so people can help you fix it.
But you know the documentation until now not released yet. So where can i read to change it?
You can't. But you can use the web developer console in your browser to track the requests.
is there a device that i can install firmware v3 other than B1300? are there any requirements such as what kind of cpu/chipset should be installed? not that i don't want to change to a new device. because it takes quite a long time to change it. so i'm looking for the fastest way. that is looking for the same device that can be installed firmware v3
How many ethernet ports do you require?
Devices that still have v3 firmware:
SFT1200 GL.iNet download center
AX1800 Flint GL.iNet download center
You would be limited to v3.216 but you would still have access to the v3 api.
If you require the API doc of SDK v4, please email to our technical team: support@gl-inet.com
Thank you for the recommendation, but yesterday I asked about that unit, my supplier said it was not available.
just asking for access or are there any conditions that I have to fulfill?
Better to provide your identity, use scenario, the number of devices you have, and which functions API needed, etc., so that we can judge the conditions to meet the conditions.
