Is there any way to disable reset button without login? I afraid parental control can be easily erased using this feature…
Parental control is not worth the paper it is written on anyway, based on its implementation. There are almost unlimited ways to get around it.
Any child (and teenager even more so!) with access to a search engine will have cracked the thing in a matter of minutes.
In the end, it's just a router, not a full firewall with dedicated features.
@admon
does that include the new Bark parental controls included in the B3000?
I would spontaneously say: Yes.
My test device is still on its way, then I'll take a closer look. Although Bark claims on their website that they also read and analyze traffic, among other things, I can't really imagine that the OpenWrt version of Bark does the same.
I would have to take a closer look.
But let's be honest: parental control is only a poor substitute for education and trust. I'd be afraid that as a parent, I'd be fooled into thinking it was a safe online experience for my child while they found a way around it.
Good parental control should be on the same level as enterprise corporate IT:
Say ...
- monitoring of internet traffic
- revocation of admin privileges
- complete control over the end device
Most solutions are already overwhelmed with 1.
I set up separate router with whitelist only. So there will be hard to bypass, probably…
Whitelist for what? DNS?
So they can just use another DNS server. Or they use an Apple device with Cloud+ - which will route all DNS traffic to Apple servers instead of your DNS server; so it won't work by design.
The only true way would be using whitelisting based on IP; and that is something nobody can handle. ![]()
Banned too
That what I did. I allowed only Telegram, Signal and Wikipedia
I don't want to offend you, but I can't really imagine that you have only unblocked the IPs of these services.
Telegram in particular is a very good example: this service even works in countries like Iran, where it has actually been blocked.
You would also block all updates and other services that are required for some devices. Without knowing the exact configuration, I can't say much - but I would doubt that you have really set up IP-based blocks.
you could physically remove the button?
This is only example. For others same config (this unblock telegram):
iptables -P INPUT DROP
iptables -A OUTPUT -d 149.154.160.0/22 -j ACCEPT
iptables -A OUTPUT -d 149.154.164.0/22 -j ACCEPT
iptables -A OUTPUT -d 91.108.4.0/22 -j ACCEPT
iptables -A OUTPUT -d 91.108.56.0/22 -j ACCEPT
iptables -A OUTPUT -d 91.108.8.0/22 -j ACCEPT
iptables -A OUTPUT -d 95.161.64.0/20 -j ACCEPT
iptables -P OUTPUT DROP
Ok, wow, that's a pretty harsh way of blocking ![]()
Did not think that you do it like this - because in my opinion, this is the most secure one, but the one with most troubleshooting issues as well. Wouldn't be my choice of parental control, tbh.
Otherwise it can be bypassed by Tor, VPN, DOH…
So how to prevent resetting this?
Not sure if it's a good idea, but doing this should disable the button:
rm /etc/rc.button/reset
Why?
Maybe copy it with cp for case if will be needed? Or no?
Because I don't know what, it might break or not. It's the sledgehammer method.
Not needed, all original files are located in /rom
Please be aware that there is a method of resetting the device you can't disable:
