Reset LTE module
I have a GL-X300B, if I accidentally change some non-volatile configuration on the Quectel EG25G module, will the router be able to reset it?
You can reset it using AT commands.
Reset the firmware in the router only suitable for the router setting, not including the modem. Reset modem by AT command: AT+QPRTPARA=3
