Reset question
I am testing plugin for router and working on developing it. I need to reset firmware from time to time to check if it works correctly.
So, if I reset firmware regularly, won’t I harm my router physically?
Reset as often as you like.
Since you are testing plugins and scripts, you can reset by using SSH firstboot command.
