Resetting GL-MT3000/Beryl AX/AX3000 Wifi router
I changed the SSID and password on my Orbic Hotspot. I cannot log into the administrative page of my GL-MT3000. I find it on the Wi-Fi list and put in my old administrative password and it does not recognize it. I tried resetting the router using the reset button (holding for 5 seconds) but the light does not stop flashing. I understand that the light should be solid when all data is cleared. I have had it powered up for over an hour and the light is still flashing. Any recommendations?
Did you happen to reference this guide?
We recommend first troubleshooting common causes of Admin Panel inaccessibility using this guide.
Cannot access web Admin Panel - GL.iNet Router Docs 4
If that doesn't resolve the issue, follow this guide to restore your device to factory settings or proceed with reflashing the firmware via Uboot.
How to Reset to factory: Repair network or reset - GL.iNet Router Docs 4
Reflashing the firmware via Uboot: What should I do if my router is bricked - GL.iNet Router Docs 4
