Hi -
Are resolutions smaller then 1920x1080 supported on the Comet? I am trying to adjust the display resolution, so it is readable, but the Comet does not adjust to these resolutions.
Thanks!
Hi -
Thanks!
Here are some resolutions, could you please try it based your monitor?
You should configure the resolution on the controlled computer instead of attempting to modify the configuration of comet
When I try to set the resolution on the computer, the Comet does not readjust for those resolutions.
Let me explain it more clearly. The resolution seen at the lower left corner of GLKVM is the actual output resolution of HDMI. WINDOWS may have made some special Settings for compatibility: no matter what resolution you switch to, what it actually outputs to the display will be the maximum supported resolution of this display. This mechanism may bring about some strange problems, such as the issue of reversed scaling
Theoretically, when you switch to an EDID that supports a maximum resolution of 2K,WINDOWS should output 2K resolution. But I'm not sure why it doesn't. I can only consider this a BUG in WINDOWS. If you use the LINUX system, you will find that it is completely different. Whatever resolution you set in the system, it will actually output that resolution. MACOS sometimes performs like WINDOWS and sometimes not
Sounds good. Thank you for that information.
