[Resolved] Ctrl + Alt + Delete doesn't work with predefined shortcut, virtual keyboard, or any other method
I am having issues sending control alt delete to unlock a windows server host. I have confirmed keyboard is getting passed normally, as if I plug in a keyboard to the machine and unlock it with ctrl alt delete, the kvm passes everything as expected (except for ctrl + alt + delete, that doesn’t work in any scope)
The ‘show virtual keyboard’ option isn’t working for me either, nor is defining a keystroke manually (for example right control + right alt + delete)
Edit: I figured out it’s because ‘Swap Command and Control for Mac OS’ setting was turned on. Turning that off works on windows machines, but I can’t figure out how to send ctrl + alt + delete on a Mac OS host with that setting on
