Hi, I would like to know if I can use this device to connect an older piece of equipment that only has a wired Ethernet jack to my network and I do not have a wired Ethernet socket in that room but I do have strong WiFi signal from my router.
I believe this is a standard capability of DD-WRT but I have not seen this discussed.
Yes, the GL.iNet firmware supports this kind of “repeater” or “bridge” mode. Depending on your other router’s firmware there are a couple ways to do it. Both are straightforward to configure.
