I was trying to get the EC25 in my GL-MiFi to work via QMI, but can’t seem to establish a connection. In fiddling with uqmi, I’m wondering if something was altered on the EC25 itself, as I can’t seem to get back to a 3g connection via ttyUSB2 or ttyUSB3 even after factory reset of the GL-MiFi.
After factory reset, comgt info gives:
Quectel
EC25
Revision: EC25AFAR05A04M4G
OKManufacturer: Quectel
IMEI and Serial Number: 861102032865021
Manufacturer’s Revision:
EC25AFAR05A04M
Hardware Revision:Network Locked: 0
Customisation:Band settings: (
APN: 1,“IP”,“fast.t-mobile.com”,“0.0.0.0”,0,0,0,0
I found it odd that the APN information would be preserved after reset, so perhaps some other setting I changed via uqmi needs to be put back? Is there a way to flash the EC25 to its original settings?
Here’s what happens in my system log when I first configure the modem after reset for UMTS/GPRS on ttyUSB2:
Fri Apr 20 09:12:53 2018 daemon.notice netifd: Interface ‘modem’ is setting up now
Fri Apr 20 09:12:55 2018 daemon.notice pppd[5154]: pppd 2.4.7 started by root, uid 0
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: abort on (BUSY)
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: abort on (NO CARRIER)
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: abort on (ERROR)
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: report (CONNECT)
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: timeout set to 10 seconds
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: send (AT&F^M)
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: expect (OK)
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: AT&F^M^M
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: OK
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: – got it
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: send (ATE1^M)
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: ^M
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: ATE1^M^M
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: send (AT+CGDCONT=1,“IP”,“fast.t-mobile.com”^M)
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: timeout set to 30 seconds
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: AT+CGDCONT=1,“IP”,“fast.t-mobile.com”^M^M
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: send (ATD991#^M)
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: expect (CONNECT)
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: ATD99**1#^M^M
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: CONNECT
Fri Apr 20 09:12:56 2018 local2.info chat[5178]: send ( ^M)
Fri Apr 20 09:12:56 2018 daemon.info pppd[5154]: Serial connection established.
Fri Apr 20 09:12:57 2018 kern.info kernel: [ 312.799734] 3g-modem: renamed from ppp0
Fri Apr 20 09:12:57 2018 daemon.info pppd[5154]: Using interface 3g-modem
Fri Apr 20 09:12:57 2018 daemon.notice pppd[5154]: Connect: 3g-modem ↔ /dev/ttyUSB3
Fri Apr 20 09:13:00 2018 daemon.warn pppd[5154]: Could not determine remote IP address: defaulting to 10.64.64.64
Fri Apr 20 09:13:00 2018 daemon.notice pppd[5154]: local IP address 100.90.164.123
Fri Apr 20 09:13:00 2018 daemon.notice pppd[5154]: remote IP address 10.64.64.64
Fri Apr 20 09:13:00 2018 daemon.notice pppd[5154]: primary DNS address 10.177.0.34
Fri Apr 20 09:13:00 2018 daemon.notice pppd[5154]: secondary DNS address 10.177.0.210
Fri Apr 20 09:13:00 2018 daemon.notice netifd: Network device ‘3g-modem’ link is up
Fri Apr 20 09:13:00 2018 daemon.notice netifd: Interface ‘modem’ is now up
Fri Apr 20 09:13:00 2018 daemon.info dnsmasq[2790]: reading /tmp/resolv.conf.auto
Fri Apr 20 09:13:00 2018 daemon.info dnsmasq[2790]: using local addresses only for domain lan
Fri Apr 20 09:13:00 2018 daemon.info dnsmasq[2790]: using nameserver 10.177.0.34#53
Fri Apr 20 09:13:00 2018 daemon.info dnsmasq[2790]: using nameserver 10.177.0.210#53
Fri Apr 20 09:13:01 2018 user.notice mwan3: ifup interface modem (3g-modem)
Fri Apr 20 09:13:01 2018 daemon.info odhcpd[2035]: Using a RA lifetime of 0 seconds on br-lan
Fri Apr 20 09:13:06 2018 user.notice firewall: Reloading firewall due to ifup of modem (3g-modem)
Fri Apr 20 09:13:06 2018 daemon.info gl-health>>: AP Ok=1
Fri Apr 20 09:13:06 2018 daemon.info gl-health>>: network(caIfnames) = wan wan6 modem
Fri Apr 20 09:13:06 2018 daemon.info gl-health>>: STA Ok=1
Fri Apr 20 09:13:06 2018 daemon.info gl-health>>: Everthing is OK!!!
Fri Apr 20 09:13:06 2018 daemon.info gl-health>>: check wpa runing =
It seems to want to use ttyUSB3 instead. The GL UI now shows an IP address and DNS addresses from the wireless carrier, but I am unable to ping either IPs (like 8.8.8.8) or domain names.
If I reboot, I get this repeatedly with no IP address from carrier showing as obtained in the GL UI:
Fri Apr 20 09:15:24 2018 daemon.notice netifd: Interface ‘modem’ is setting up now
Fri Apr 20 09:15:26 2018 daemon.notice pppd[6488]: pppd 2.4.7 started by root, uid 0
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: abort on (BUSY)
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: abort on (NO CARRIER)
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: abort on (ERROR)
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: report (CONNECT)
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: timeout set to 10 seconds
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: send (AT&F^M)
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: expect (OK)
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: AT&F^M^M
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: OK
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: – got it
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: send (ATE1^M)
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: ^M
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: ATE1^M^M
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: send (AT+CGDCONT=1,“IP”,“fast.t-mobile.com”^M)
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: timeout set to 30 seconds
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: AT+CGDCONT=1,“IP”,“fast.t-mobile.com”^M^M
Fri Apr 20 09:15:27 2018 local2.info chat[6524]: send (ATD991#^M)
Fri Apr 20 09:15:28 2018 local2.info chat[6524]: expect (CONNECT)
Fri Apr 20 09:15:28 2018 local2.info chat[6524]: ^M
Fri Apr 20 09:15:28 2018 local2.info chat[6524]: ATD99**1#^M^M
Fri Apr 20 09:15:28 2018 local2.info chat[6524]: CONNECT
Fri Apr 20 09:15:28 2018 local2.info chat[6524]: – got it
Fri Apr 20 09:15:28 2018 local2.info chat[6524]: send ( ^M)
Fri Apr 20 09:15:28 2018 daemon.info pppd[6488]: Serial connection established.
Fri Apr 20 09:15:28 2018 kern.info kernel: [ 201.054766] 3g-modem: renamed from ppp0
Fri Apr 20 09:15:28 2018 daemon.info pppd[6488]: Using interface 3g-modem
Fri Apr 20 09:15:28 2018 daemon.notice pppd[6488]: Connect: 3g-modem ↔ /dev/ttyUSB3
Fri Apr 20 09:15:30 2018 daemon.notice pppd[6488]: Modem hangup
Fri Apr 20 09:15:30 2018 daemon.notice pppd[6488]: Connection terminated.
Fri Apr 20 09:15:31 2018 daemon.info pppd[6488]: Exit.
Fri Apr 20 09:15:32 2018 daemon.notice netifd: Interface ‘modem’ is now down
For some reason, it seems to want to now use ttyUSB3 instead of ttyUSB2 (was that com port used for something different when I tried QMI and now unavailable?). If I make any subsequent changes to the modem config at this point (like explicitly switching between ttyUSB2 and ttyUSB3 in the GL UI, for example), I notice duplicate interface config entries in the system log.
Fri Apr 20 09:24:24 2018 daemon.info gl-health>>: network(caIfnames) = wan wan6 modem modem
And eventually…
Tue Jul 10 17:26:43 2018 daemon.info gl-health>>: network(caIfnames) = wan wan6 modem modem tethering modem modem modem
Any ideas on how to restore the serial connectivity that I had before testing QMI?
