Rigid Regex in /usr/sbin/gl-ngx-session causes infinite crash loop on GL-BE9300 (v5 Firmware)
Description
On the GL-BE9300 (Flint 3) running Firmware v5 , the service eco (managed via /usr/sbin/gl-ngx-session) enters an infinite crash loop with the error daemon.err eco: get nginx port fail. This failure blocks the GL.iNet Mobile App from loading data, often resulting in "Password changed" or "Error 500" messages.
Root Cause
The Lua script /usr/sbin/gl-ngx-session uses a rigid regular expression to determine the Nginx port from /etc/nginx/conf.d/gl.conf. The specific code is: local port = conf:match('listen (%d+);')
If a user modifies the listen directive to bind Nginx to a specific IP—such as the LAN IP 192.168.31.1:80—the regex fails to capture the port number and returns nil. This lack of a valid return value causes the script to crash repeatedly.
The Necessity of IP-Binding (Use Case)
Binding the router's Nginx explicitly to the LAN IP (192.168.31.1) is a required configuration for users hosting their own Nginx Proxy Manager (NPM) or similar reverse proxies on internal servers (e.g., Unraid).
Default Behavior: By default, Nginx listens on all interfaces (0.0.0.0).
  • Conflict: When a user in the LAN tries to access their own public domain (e.g., assistances.de), the router's Nginx captures the packet on port 443/80 before the firewall can apply Port Forwarding rules.
  • Solution: Binding the router-Nginx to the LAN IP only keeps the WAN interface ports "free". This allows Hairpin-NAT (NAT Loopback) to function correctly, directing traffic to the internal proxy server (e.g., .228) instead of the router's own administration page.
Steps to Reproduce
  1. Modify /etc/nginx/conf.d/gl.conf to use an IP-bound listener: listen 192.168.31.1:80; instead of the default listen 80;.
  2. Restart Nginx and gl-ngx-session.
  3. Observe logread -f | grep eco showing constant get nginx port fail errors.
Workaround Found
Inserting a commented-out standard listener line—e.g., # listen 80;—at the top of gl.conf allows the regex to find a match, stopping the crash loop while keeping the actual active IP-binding intact.
Requested Fix
Update the regex in /usr/sbin/gl-ngx-session to properly handle IP-bound addresses and optional spaces. A more robust matching pattern would be: conf:match('listen%s+[%d%.%:]*:(%d+);') This would allow the service to remain stable even when Nginx is configured for advanced routing and local server isolation.
Thank you for your feedback.
We have reported this to our development team for further investigation and a possible fix in a future release.
