RM1 KVM in US, Reverse Proxy in CN, Configure TURN relay
Team, I have a VM in China (on AliYun) joined to my Tailscale network. That vm is also configured as a Tailscale Personal Relay (not sure if that matters).
I have Nginx running on that VM, serving up the RM1 via tailscale IP address.
However whenever I connect, it uses a relay server for the WebRTC/H.264 feed. Can you tell me what I can install on the Reverse Proxy (or somewhere else) to put a turn relay and how to configure it to reduce the extra hops going through the GLInet one?
Disable GL Cloud, and add your own turn services in this file.
`/tmp/turnserver.json`
