RM1 stuck no lights only showing Maskrom
The RKtool wont allow me to select a firmware file “Loading firmware failed”
No lights on the unit , I’m cooked.
This generally only occurs when the eMMC is empty. Have you used a brick recovery tool to flash something unknown into it, causing it to fail?
I followed a post on your forums to flash a firmware to enable wifi
After flashing glkvm-RM1PE-1.8.2-0509-1778298663.img
It turned into a brick.
I just wanted to get wifi working , I bought the right adapter according to posts but 1.92 firmware had missing wifi elements hence flashing
Im sorry , I failed.
RKDevTool_Release_v3.37.zip (2.7 MB)
Use this one.
Do not attempt to flash firmware across different models.
Hi Thanks for this my rm-1 is now functioning, your a superstar!!
Are there any plans to enable the AR9271 usb wifi dongle to work with this software, this was ultimately what I was trying to achieve before I bricked it before?
Yeah, in a previous version, I mistakenly placed the Wi-Fi firmware in the wrong location. It will be usable in the next release, or you can manually copy the firmware to the correct location.```
cp -rf /usr/lib/firmware/* /lib/firmware/
