RM10 won't reconnect the WiFi
After my WiFi restarted, the RM10 won't reconnect to it automatically...
Really handy for some situations.
@WyvernLang Hi, can you send me your log via private message?
Is there any progress?
Hi, the current software doesn't handle reconnection well. We've already optimized it in the new firmware, and we expect to push a beta version to the official website today or tomorrow. I'll notify you when the update is complete.
Hi @WyvernLang
Could you try the latest beta firmware? GL.iNet download center
Solved!
And the new functions work well, Thank you!
Moreover, the RM10 always seems to connect to 2.4G instead of MLO or others.
Should it try to connect to the faster band after a while?
That will be perfect!
Hi, the latest firmware optimizes the Wi-Fi connection strategy, selecting a Wi-Fi AP based on channel ratings. Can you share your logs with me via a private link so I can determine why the RM10 always seems to connect to 2.4G instead of MLO or other bands? Thanks.
Can you leave me an email?
I don't know how to use the private message on the GLINET well...
I remember I had sent you the log file privately through the GLINET forum, but it seems didn’t succeed.
I updated your user level; you can now send PMs by hovering over the user you want to send the PM to.
Have you received my PMs?
I did reply, but I'm not sure if you were able to receive it.
Hi, this log does not contain Wi-Fi connection logs. Could you manually connect and then provide another copy?
I have obtained the new logs and confirmed that this issue has been optimized in the new version. We will provide the optimized firmware as soon as possible. Thanks.
Hi, could you try the latest beta firmware? GL.iNet download center
Hi, the issue is not resolved:
RM10, updated to latest 1.9.1 release1, connecting to a FLINT3E router (latest stable 4.8.8, which was published recently).
About every roughly 2 days, the RM10 looses wifi and doesn’t try to reconnect. Only way is to power off and on then it connects again for roughly 48 hours.
The flint3e has 3 SSIDs active (MLO, 5ghz, 2.4).
I feel it could be either a flint3e firmware issue or RM10. I just disabled MLO on the flint3e to see if the RM10 stays online longer.
How to share/upload logs (privately)?
You can click on my avatar to send a message and attach the log file.
Dhcp for glinet KVM is broken since 1.8.x firmware.
After a few days it will disconnect and not reconnect until you power cycle. Happens to both wired and wireless.
You need to static assign ip. Although I think glinet web UI does not manage wifi fully and static assign of wifi may not be possible.
in my flint3e the IP of the RM10 is already configured as fixed IP address. Do I need to change a setting in the RM10 too?
Something i noticed: i disabled MLO SSID (i had 3 SSIDs: 2.5G, 5G and MLO active) from the flint3e and now it seems that the RM10 is able to hold the connection with the 5G network.
Does the FLINT3E router use Ethernet or Wi-Fi for its uplink connection?
The flint3e is connected to my internet box with 2.5GB/s ethernet cable.
Also related to flint3e, the Pixel 6 phone from wife now struggles to connect to the 5Ghz access point too.
Since i disabled the MLO SSID couple days ago, i haven’t experimented any drop in 5ghz connection from the RM10.
Hi, could you please test the latest 1.10 beta firmware on the GL.iNet download center ? Our tests confirm that even when the upstream Wi-Fi router automatically reboots every 8 minutes, the Comet Pro successfully reconnects every single time. If you still encounter issues, we would appreciate it if you could share FLINT3E's Wi-Fi configuration and the Comet Pro logs.
