Since I got the device a few weeks ago, it has shut down my host machine twice randomly. The first time it also managed to turn it back on after a minute. Here is the entire log from today (12th) until I used the KVM to power it back on at 13:28.
It is running firmware 1.9.1 release1.
You can see the ATX command where I powered it on, but no command to turn it off, in fact no entries in the log at all until a few minutes after proxmox received the power off command.
Proxmox Log:
Sep 12 12:36:25 vms1 systemd-logind[1196]: Power key pressed short.
Sep 12 12:36:25 vms1 systemd-logind[1196]: Powering off...
Sep 12 12:36:25 vms1 systemd-logind[1196]: System is powering down.
kvmd.log:
2026-09-12 12:39:55,701 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [1 times]
2026-09-12 12:39:55,904 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [2 times]
2026-09-12 12:39:55,950 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- resolution: no signal, deinit rv1126 encoder
2026-09-12 12:39:55,951 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- Stopping VO deal thread
2026-09-12 12:39:55,967 - kvmd.apps.kvmd.streamer - INFO - => -- ERROR [0.000 tid=314] -- get VENC data failed 1 times a004800e
2026-09-12 12:39:56,067 - kvmd.apps.kvmd.streamer - INFO - => -- ERROR [0.000 tid=314] -- get VENC data failed 2 times a004800e
2026-09-12 12:39:56,077 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=331] -- MJPEG fetch thread stopped
2026-09-12 12:39:56,078 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- VO deal thread stopped
2026-09-12 12:39:56,079 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- Stopping MJPEG fetch thread
2026-09-12 12:39:56,094 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=330] -- MJPEG fetch thread stopped
2026-09-12 12:39:56,095 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- MJPEG fetch thread stopped
2026-09-12 12:39:56,294 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_SYS_UnBind vpss[0, 1] to snapshot venc[1]: 0
2026-09-12 12:39:56,296 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_SYS_UnBind vpss[0, 0] to venc[0]: 0
2026-09-12 12:39:56,297 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_SYS_UnBind vi[0, 8] to vpss[0, 0]: 0
2026-09-12 12:39:56,299 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VENC_StopRecvFrame[1]: 0
2026-09-12 12:39:56,300 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VENC_DestroyChn[1]: 0
2026-09-12 12:39:56,301 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VENC_StopRecvFrame[0]: 0
2026-09-12 12:39:56,303 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VENC_DestroyChn[0]: 0
2026-09-12 12:39:56,304 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VPSS_StopGrp[0]: 0
2026-09-12 12:39:56,305 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VPSS_DisableChn[0, 2]: 0
2026-09-12 12:39:56,306 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VPSS_DisableChn[0, 1]: 0
2026-09-12 12:39:56,308 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [4 times]
2026-09-12 12:39:56,309 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VPSS_DisableChn[0, 0]: 0
2026-09-12 12:39:56,310 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VPSS_DestroyGrp[0]: 0
2026-09-12 12:39:56,313 - kvmd.plugins.hid.otg - DEBUG - Link state changed to: False
2026-09-12 12:39:56,870 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VI_DisableChn[0, 0]: 0
2026-09-12 12:39:56,872 - kvmd.apps.kvmd.streamer - INFO - => -- INFO [0.000 tid=332] -- RK_MPI_VI_DisableDev[0]: a0088007
2026-09-12 12:39:57,115 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [8 times]
2026-09-12 12:39:58,734 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [16 times]
2026-09-12 12:39:59,920 - kvmd.plugins.atx.glatx - INFO - ATX状态变化: {'enabled': True, 'busy': False, 'power': 'off', 'leds': {'power': False, 'hdd': False}}
2026-09-12 12:40:01,971 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [32 times]
2026-09-12 12:40:08,446 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [64 times]
2026-09-12 12:40:21,400 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [128 times]
2026-09-12 12:40:47,304 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [256 times]
2026-09-12 12:41:39,105 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [512 times]
2026-09-12 12:43:22,663 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [1024 times]
2026-09-12 12:46:49,682 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [2048 times]
2026-09-12 12:53:43,700 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [4096 times]
2026-09-12 13:07:31,923 - kvmd.plugins.hid.otg.device - DEBUG - HID-keyboard is busy/unplugged (write select) [8192 times]
2026-09-12 13:28:54,378 - kvmd.plugins.atx.glatx - INFO - Executed ATX command 'click_power_short'
2026-09-12 13:28:55,857 - kvmd.plugins.hid.otg - DEBUG - Link state changed to: True
2026-09-12 13:28:58,339 - kvmd.plugins.atx.glatx - INFO - ATX状态变化: {'enabled': True, 'busy': False, 'power': 'on', 'leds': {'power': False, 'hdd': False}}
