I have an AR-750S that just arrived yesterday. I ran through the initial setup to set the Admin password. However, when I use the same password for root under advanced settings, the password doesn’t work.
I’ve factory reset the device several times by holding the reset button for at least 10 seconds. Each time it takes me through setup again where I enter the Admin password, but each time the root password doesn’t work. I also downloaded the openwrt-ar750s-3.009.img file from the GL.iNet website to try and reapply the image using the “bricked device” uboot method. Again, the admin password works but the root password does not.
Running firmware version 3.0009. It seems like the reset is not performing a complete reset.
Are there any other suggestions on what I can try? Please advise.
I have another AR750S with the same password, and it seems to work with the root password. The only difference is that the other one was purchased awhile ago (pre-3.009). I configured that one and then upgraded to 3.009. However, on this problem one it came with 3.009 already installed.
That sounds like a good point, perhaps I’ll try to flash an older firmware, confirm the password works for both admin and root and then re-upgrade.
That did the trick. I flashed version 3.007 on the device using UBoot. After reboot on version 3.007, I went through setup again. This time the complex password i used worked for both admin and root. Next, I upgraded to 3.009. After reboot, the password works for root and admin as expected on 3.009.
This issue is resolved now. Thanks for the assistance.
I had a similar problem. I set the password initially when I first connected but that password didn’t work for root. I decided to try something and went into the password change area under “More Settings” and “reset” my password (just put the old one in 3 times) and this updated the root password correctly.
