Hello, i am often travelling to countries with DPI firewall. In most cases i use a stunnel configuration to obfuscate my openvpn traffic through an ssl tunnel.
I would like to know what would be the best way to put the right routes into my AXT1800 router. I have successfully setup the stunnel configuration from luci. i can connect the openvpn tunnel from the gl inet frontend through the stunnel proxy using its local address and port configured in stunnel. In order to keep the connection up i would then need to setup a route which tells the router to not route the initial ip of the stunnel / proxy gateway through the vpn but directly through the internet gateway otherwise the vpn would stop working. Whats the best way to put this route and where?
Example:
Router IP: 10.10.1.1
Stunnel / Proxy IP: 10.10.2.1 as destination and 127.0.0.1:6666 as local recipient
Openvpn: Configured to connect through stunnel /proxy with 127.0.0.1:6666 as destination
After establishing the vpn th proxy ip 10.10.2.1 should not be routed through vpn otherwise the proxy will end up in a reconnect loop
Are there any other rules / routes required to have this setup working properly on the gl inet router?
Thank you!
