Hi support,
Are you aware of issues like this - my router crashed suddenly. I'm not too tech savvy, so please see some information
Crash Log:
Oops#1 Part1
<6>[ 20.117435] br-lan: port 7(wlan0) entered disabled state
<6>[ 20.165516] br-lan: port 7(wlan0) entered blocking state
<6>[ 20.170842] br-lan: port 7(wlan0) entered disabled state
<6>[ 20.176303] mt798x-wmac 18000000.wifi wlan0: entered allmulticast mode
<6>[ 20.183121] mt798x-wmac 18000000.wifi wlan0: entered promiscuous mode
<6>[ 20.682496] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
<7>[ 25.396721] [add_dev_config 287]add node success. iface:wan, dev:pppoe-wan, ifindex:17
<6>[ 30.751295] br-lan: port 7(wlan0) entered blocking state
<6>[ 30.756642] br-lan: port 7(wlan0) entered forwarding state
<6>[105260.584776] mt7530-mdio mdio-bus:1f lan2: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[105260.584798] br-lan: port 2(lan2) entered blocking state
<6>[105260.598084] br-lan: port 2(lan2) entered forwarding state
<6>[105364.513492] br-lan: port 2(lan2) entered disabled state
<6>[105364.513601] mt7530-mdio mdio-bus:1f lan2: Link is Down
<6>[105386.468874] mt7530-mdio mdio-bus:1f lan2: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[105386.468900] br-lan: port 2(lan2) entered blocking state
<6>[105386.482190] br-lan: port 2(lan2) entered forwarding state
<6>[105414.374525] br-lan: port 2(lan2) entered disabled state
<6>[105414.374638] mt7530-mdio mdio-bus:1f lan2: Link is Down
<1>[279613.713020] Unable to handle kernel paging request at virtual address dead000000000100
<1>[279613.721192] Mem abort info:
<1>[279613.724106] ESR = 0x0000000096000004
<1>[279613.727972] EC = 0x25: DABT (current EL), IL = 32 bits
<1>[279613.733426] SET = 0, FnV = 0
<1>[279613.736569] EA = 0, S1PTW = 0
<1>[279613.739785] FSC = 0x04: level 0 translation fault
<1>[279613.744819] Data abort info:
<1>[279613.747781] ISV = 0, ISS = 0x00000004, ISS2 = 0x00000000
<1>[279613.753413] CM = 0, WnR = 0, TnD = 0, TagAccess = 0
<1>[279613.758551] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
<1>[279613.764028] [dead000000000100] address between user and kernel address ranges
<0>[279613.771315] Internal error: Oops: 0000000096000004 [#1] SMP
<7>[279613.776967] Modules linked in: pppoe ppp_async option wireguard usb_wwan rndis_host qmi_wwan pppox ppp_generic nft_fib_inet nf_flow_table_inet mt7915e(O) mt76_connac_lib(O) mt76(O) mac80211(O) libchacha20poly1305 ipt_REJECT huawei_cdc_ncm chacha_neon cfg80211(O) cdc_ncm cdc_ether xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_quota xt_pkttype xt_owner xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_cgroup xt_addrtype xt_TPROXY xt_TCPMSS xt_REDIRECT xt_MASQUERADE xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY usbserial usbnet ts_fsm ts_bm slhc sch_cake poly1305_neon nft_tproxy nft_socket nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_numgen nft_nat nft_masq nft_log nft_limit nft_hash nft_flow_offload nft_fib_ipv6 nft_fib_ipv4 nft_fib nft_ct nft_compat nft_chain_nat nf_tproxy_ipv6 nf_tproxy_ipv4 nf_tables nf_socket_ipv6 nf_socket_ipv4 nf_reject_ipv4 nf_nat_tftp
<7>[279613.777151] nf_nat_snmp_basic nf_nat_pptp nf_nat_irc nf_nat_h323 nf_nat_amanda nf_log_syslog nf_flow_table nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sane nf_conntrack_pptp nf_conntrack_netlink nf_conntrack_netbios_ns nf_conntrack_irc nf_conntrack_h323 nf_conntrack_broadcast ts_kmp nf_conntrack_amanda nf_conncount mdio_netlink(O) libcurve25519_generic libcrc32c libchacha iptable_nat iptable_mangle iptable_filter ipt_ECN ipheth ip_tables compat(O) cdc_wdm cdc_acm br_netfilter asn1_decoder arptable_filter arpt_mangle arp_tables crypto_safexcel fuse sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat
<7>[279613.865950] nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6t_NPT ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb ip6_udp_tunnel udp_tunnel udp_diag tcp_diag raw_diag inet_diag tun ntfs nls_utf8 nls_iso8859_1 nls_cp437 sha512_arm64 sha1_ce sha1_generic seqiv md5 geniv des_generic libdes authencesn authenc uas usb_storage leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd xhci_hcd uhci_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl kmwan(O) ehci_hcd gpio_button_hotplug(O) gl_sdk4_tertf(O) gl_sdk4_black_white_list(O) vfat fat exfat usbcore usb_common aquantia mii gl_sdk4_hw_info(O)
<7>[279614.011751] CPU: 1 PID: 9007 Comm: lua Tainted: G O 6.6.63 #0
<7>[279614.018955] Hardware name: GL.iNet GL-MT6000 (DT)
<7>[279614.023728] pstate: 80400005 (Nzcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
<7>[279614.030757] pc : subnet_free+0x804/0xda0 [gl_sdk4_tertf]
<7>[279614.036148] lr : subnet_free+0x824/0xda0 [gl_sdk4_tertf]
<7>[279614.041531] sp : ffffffc089d63b90
<7>[279614.044916] x29: ffffffc089d63b90 x28: ffffffc080e9d8d0 x27: ffffff800b77b820
<7>[279614.052119] x26: ffffff800b77b818 x25: ffffffc07918b500 x24: ffffff800b77b7e8
<7>[279614.059322] x23: ffffffc07918b508 x22: ffffffc080e9e1e8 x21: ffffff80014324b0
<7>[279614.066524] x20: ffffff800b77b828 x19: dead000000000100 x18: 0000000000000000
<7>[279614.073727] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000010
<7>[279614.080928] x14: 0000000000000000 x13: ffffffc089d63b90 x12: ffffffc089d63b90
<7>[279614.088131] x11: 00000000ffffffd0 x10: ffffffc089d63b60 x9 : ffffffc089d63b90
<7>[279614.095334] x8 : 000000000000013b x7 : 0000000000000032 x6 : 0000000000000008
<7>[279614.102536] x5 : ffffffc080ab31e0 x4 : ffffffffffffffff x3 : 0000000000000000
<7>[279614.109737] x2 : ffffffc080b48e38 x1 : 0000000000000114 x0 : 000000000000013b
<7>[279614.116940] Call trace:
<7>[279614.119458] subnet_free+0x804/0xda0 [gl_sdk4_tertf]
<7>[279614.124495] seq_read_iter+0xdc/0x488
<7>[279614.128233] seq_read+0x78/0x98
<7>[279614.131448] proc_reg_read+0xb0/0x100
<7>[279614.135186] vfs_read+0xa4/0x278
<7>[279614.138488] ksys_read+0x60/0xe8
<7>[279614.141787] __arm64_sys_read+0x20/0x30
<7>[279614.145696] invoke_syscall.constprop.0+0x54/0xf0
<7>[279614.150472] do_el0_svc+0x44/0xc8
<7>[279614.153859] el0_svc+0x18/0x50
<7>[279614.156989] el0t_64_sync_handler+0x118/0x128
<7>[279614.161416] el0t_64_sync+0x150/0x158
<0>[279614.165153] Code: 95c49f07 f9400273 eb14027f 54000180 (f9400263)
<4>[279614.171313] ---[ end trace 0000000000000000 ]---
Panic#2 Part1
<3>[279614.180038] pstore: backend (ramoops) writing error (-28)
<0>[279614.185508] Kernel panic - not syncing: Oops: Fatal exception
<2>[279614.191321] SMP: stopping secondary CPUs
<0>[279614.195316] Kernel Offset: disabled
<0>[279614.198874] CPU features: 0x0,00000000,00000000,1000400b
<0>[279614.204255] Memory Limit: none
Luci System Info:
System
| Hostname | GL-MT6000 |
| Model | GL.iNet GL-MT6000 |
| Architecture | ARMv8 Processor rev 4 |
| Target Platform | mediatek/filogic |
| Firmware Version | OpenWrt 24.10.0-rc2 r28161-ea17e958b9 / LuCI openwrt-24.10 branch 24.337.27339~b1968d9 |
| Kernel Version | 6.6.63 |
| Local Time | 2025-04-13 20:06:08 |
| Uptime | 0h 19m 33s |
| Load Average | 0.16, 0.30, 0.25 |
