Router features going forward after the remote exploit
I personally never wanted to enable remote access / cloud features on my router due to potential exploits / hacks but if I want to use DPI and some features on my Brume then I need to have GoodCloud enabled.
With the recent disclosure of a vulnerability due to GoodCloud being enabled and exploited, will the team at glinet look at implementing a way to use the advertised features solely local on the devices rather than relying on GoodCloud?
Or at least some other way to offer the features without exposing all the router...
We are tracking a lot of info here: Discord
what i would like to see is glinet step back from introducing or developing new features, as well as anything to do with new products. You guys need to fix basic security and functionality of current existing products.
Thank you for your feedback.
DPI identifies traffic locally on the router, and you can view traffic statistics in the router’s local admin panel with GoodCloud remote access turned off.
When you mentioned “DPI and some features,” which specific features did you have in mind?
When I first started out with the Brume 3 I was a beta tester and we needed to connect to GoodCloud in order for the DPI "license" to work and update. I was under the impression that in order for the DPI and content filtering to update then it needed a way to communicate with goodcloud to receive the database updates?
Yes, the router needs to connect to GoodCloud to obtain its DPI license and download updates to the signature database used by DPI and content filtering.
You can still use DPI and update the signature database without binding your router to a GoodCloud account.
On beta firmware we needed to bind the device, so that's not required now?
If the DPI license and updates are managed via GoodCloud then does that mean our devices are always talking to the GoodCloud services even if we don't bind them? In other words, with the recent GoodCloud exploit any device could have been infected even if they were not bound inside the GoodCloud gui?
I just need some more clarification as to how the database updates etc as originally we did need to create a goodcloud account and bind them.
I'd like clarification on this as well. I never enabled Goodcloud on my Flint2, but I did use the Data Statistics and Content Filtering features.
It doesn't seem to be. I got my Brume 3 a few days ago and was able to enable DPI without touching Goodcloud.
