Router GL-MT1300
After the firmware update, the router stopped starting. There is a programmer, but there is no source file to restore the router’s functionality. I ask for help, friends.
What firmware did you upgrade from?
What was flashed?(Stable OS, Beta OS,Snapeshot OS)
Did you try to reset to factory first?
You maybe able to use Uboot.
I flashed the bootloader firmware, after which the router stopped turning on, the situation is exactly the same as in this topic. Recovery MT1300
So you have the UART output?
If it is the same as the post then you defiantly cleared something out that was no supposed to be.
U-Boot 1.1.3 (Nov 2 2020 - 19:47:54)
Board: Ralink APSoC DRAM: 256 MB
relocate_code Pointer at: 8ff90000
Config XHCI 40M PLL
flash manufacture id: c2, device id 20 19
find flash: MX25L25635E
*** Warning - bad CRC, using default environment
Ralink UBoot Version: 5.0.0.0
ASIC MT7621A DualCore (MAC to MT7530 Mode)
DRAM_CONF_FROM: Auto-Detection
DRAM_TYPE: DDR3
DRAM bus: 16 bit
Xtal Mode=3 OCP Ratio=1/3
Flash component: SPI Flash
Date:Nov 2 2020 Time:19:47:54
icache: sets:256, ways:4, linesz:32 ,total:32768
dcache: sets:256, ways:4, linesz:32 ,total:32768
The CPU freq = 880 MHZ
estimate memory size =256 Mbytes
#Reset_MT7530
set LAN/WAN LLLLW
RESET button is pressed for: 0 second(s)
Catution: RESET button wasn't pressed or not long enough!
Continuing normal boot...
Trying Eth0 (10/100-M)
Waitting for RX_DMA_BUSY status Start... done
ETH_STATE_ACTIVE!!
Hit 'gl' to stop autoboot: 0
Device don't have ART,please write the default ART first...
MT7621 #
As I understand it, I need the same files as in this topic to restore the router, but I don’t know where to get them. Recovery MT1300 - #11 by Rinat
You need to send a picture of the bottom sticker to support was the solution, they should reach out with the .bin files
I sent a photo of the bottom sticker of the router and a photo of the uart log to [email protected] but support is silent.
You created two tickets 2 days ago. We replied one instantly and replied another today.
