Router-reset what's possible
I have a GL inet slate that I VPN into at a condo I rent. I lost connectivity a month ago, and went to check. The router had the same password, the same SSID, but lost all VPN settings… Is that even possible?
That is unlikely to happen.Don’t you have anything else to do?
What is the old firmware version and new firmware version.
Did you enable auto update?
