Router reset
how can I reset to factory with gl.inet packages…
I have uboot the rooter to openwrt, but can’t see the gl.inet interface anyway.
thanks
You need to flash the correct firmware for your device from here:
https://dl.gl-inet.com
Using uboot.
Thanks which one is for my gl mt300n v2? The mango router. I tried several firmwares but only OpenWrt afterwards.
Thanks
Either
Stable 3.102
or
Testing 3.104
Both Gl.Inet firmwares (with Gl.iNet GUI)
Uboot
To get the Mango into uboot:
  1. Remove power cable
  2. Insert LAN cable into LAN port
  3. Hold down reset button and keep held down
  4. Insert Power cable
  5. The power (left) light will come on solid
  6. The Wifi (right) light will flash 5 times
  7. When you have the power (left) and activity (middle ) lights solid release the reset button
  8. You should now be in uboot mode (192.168.1.1)
I find the gl.inet instructions a bit ambiguous
Hope this helps.
thanks so much I will have a try.
