Is adding to this thread the appropriate way to give feedback or is there a more official way? I'll proceed assuming this will get to Tristan.
Flint 2 running GL-iNet v4.9.1-op25
This is an incredibly great tool, but there is some incorrect/misleading information displayed.
Network / Network Map
- CURRENT DEVICES shows 8. The Gl-iNet CLIENTS display shows 7 online.
- WIRED shows 0. I have 4 Ethernet-attached online devices right now.
- Current clients list shows "LAN/unknown attachment" on each of the wired devices
- Current clients list shows "LAN/unknown attachment" for a device that is offline and only has WiFi attachment.
Network / DHCP / Static reservations
- It shows 4 items (correctly) but only the first shows the hostname.
The one showing a name was reserved via the GI-iNet console. The other 3 were reserved through LuCI. - Selecting "View client" for the unnamed entries displays the correct information - including a hostname.
Network / Port Forwarding
- RouterPilot says I have no port forwarding rules.
I have 7 of them, but all defined through LuCI. If you show only those defined through the GL-iNet GUI you should make that clear. I briefly have a mild panic attack when I was told I hod none.
Plug-ins
- PACKAGE INDEX show "Unavailable".
- The next line shows "Installed package information is unavailable"
The GL-iNet GUI lists 591 installed packages on my router.
I don't know if this is a function you just don't have working yet, or if I have something something wrong on my router, but I'm not sure this is a fuction that is really needed in RouterPilot. Both the GL-iNet GUI and LuCI do a pretty good job listing, installing, and deleting plug-ins. Maintaining plug-ins is not really part of the daily operational information and activity that RouterPilot excels at.
I hope you can continue working on this tool. I look forward to the next update.
