I can access the AR300 (10.0.5.100) from the Slate.
On the Slate side, I’ve added a route for any traffic 10.0.0.0/24 to use the gateway of 10.0.5.100 but I still cannot access my Synology or the AR300 on its native ip of 10.0.0.1.
Instead, I suggest you set up Port Forwarding of all the required ports (DSM-5000/5001, SMB, HTTP, HTTPS, SSH, etc.) from WAN to LAN. Alternatively, you can put the Synology NAS in the DMZ that should forward all ports.
I doubt the GL-AR300M as a wireless repeater/repeater will provide much throughput for a NAS, especially only over the 2.4GHz band,.
