Is there a way to read RSSI, TX/RX speeds, etc, when using Repeater mode? I’m using a Flint 3 running 4.8.3.
The RSSI and TX/RX rate information could be obtained via SSH into the router and execute the following command:
# Use this command to find out which STA interface was used.
iwinfo
# Then use this command to check related information. Normally, it's sta0 for 2.4 GHz, sta1 for 5 GHz and sta2 for 6 GHz.
iwinfo sta1 assoclist
