RTSP passthrough kmod-ipt-nathelper-rtsp missing
I had issues with letting RTSP packages through my Brume II with connection dropping or not working properly. I read you should install the package kmod-ipt-nathelper-rtsp for making nat firewall to route RTSP better, but that package seems to be missing in the Brume II package catalog. Why?
Temporarily, you can login visa SSH and allows it in firewall till GL provide this package.
Can this help?
https://forums.gentoo.org/viewtopic-p-6587325.html
Hello @mkdr!
I’m facing the same issue as my GL-AX1800 (Flint) doesn’t have the package available within the catalog. Have you been able to solve it somehow?
Thanks!
Im facing the same issue in my new Flint 2, no IPTV VoD or timeshift contents due to this :frowning:
Hi all Im back with good news :). I opened a case with support (via general inquiry) and they added the packaged to the repos, they wrote to me today saying that it was available and yes it is :slight_smile: :
root@GL-MT6000:~# opkg update
Downloading https://fw.gl-inet.com/releases/mt798x/kmod-4.5.7/aarch64_cortex-a53/mediatek/mt7986/Packages.gz
Updated list of available packages in /var/opkg-lists/glinet_core
Downloading https://fw.gl-inet.com/releases/mt798x/packages-4.5/aarch64_cortex-a53/glinet/Packages.gz
Updated list of available packages in /var/opkg-lists/glinet_gli_pub
Downloading https://fw.gl-inet.com/releases/mt798x/packages-4.5/aarch64_cortex-a53/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/glinet_gli_packages
Updating database.
Database update completed.
root@GL-MT6000:~# opkg install kmod-ipt-nathelper-rtsp
Installing kmod-ipt-nathelper-rtsp (5.4.238+3.21-1) to root...
Downloading https://fw.gl-inet.com/releases/mt798x/kmod-4.5.7/aarch64_cortex-a53/mediatek/mt7986/kmod-ipt-nathelper-rtsp_5.4.238%2b3.21-1_aarch64_cortex-a53.ipk
Configuring kmod-ipt-nathelper-rtsp.
Updating database.
root@GL-MT6000:~#
In my case (Flint 2 running 4.5.8), my IPTV service now works perfect (Movistar Spain) with the pending stuff that didnt work without this package (timeshift/VoD related stuff, because live iptv worked fine).
I hope this helps other users, and kudos to the support team that was able to add the package without waiting for a future software release for this to be fixed.
