Running a PXE server - serving ISOs on the SD card?
Hi!
Has anyone managed to set up a PXE TFTP boot server, serving ISOs off the SD card? I'm a techie and use my AXT1800 a lot to do things like set up servers with new operating systems and the likes.
Would appreciate a walkthrough guide if there is one, or just some pointers to get me going in the right direction :slight_smile:
Many thanks!
Seems unable to support.
It requires to the PXE NIC and the PXE Bootloader.
I believe PNX wants the AXT1800 to act as PXE SFTP boot SERVER, not boot the router itself from PXE.
I believe a guide such as this one should get someone a long way. USB-storage is already present on the AXT1800.
dnsmasq already has support for providing PXE/TFTP services. You might need NFS-Services in addition to just sftp, which could be provided using nfs-kernel-server.
Correct, thanks for clarifying my post.
I will give the guide in your post a go. Thank you!
