I’m looking for a router to put on the roof of our RV, which will go inside a Winegard 360 enclosure. It looks like this:
Here’s the reasons why I want it on the roof:
- The LTE USB modem has an operating temperature range of -30 °C to +70 °C. This modem will be inside the 360.
- I can connect the LTE modem via USB using a short cable within the Winegard device.
- I’ll get better WiFi range to pick up campground WiFI with the Wifi antennas on the roof. I’ll have another GL-inet device inside the RV acting as an access point. This will allow me to flip to the campground WiFi if LTE is out of range.
Here’s my concern:
The operating range of all Gl-Inet devices is seems to be 0 ~ 40°C (32 ~ 104°F). However, it’ll get much hotter inside the winegard. Measured up to 129 degrees when it’s 110 degrees outside.
The commercial gl-inet stuff doesn’t seem be purchasable…or did I miss something?
Any suggestions? I’d like to make GL-Inet stuff work as their products seem good otherwise.
I can’t seem to find a GL-INet with external/SMA WiFi antennas. Perhaps I missed a product?
Even inside the trailer gets up to around 100-105 while stored. The current router we have has an operating temp range of -25℃ – +65℃, but it’s not a very good router TBH.
-Mitch
