Hi.
I have an S1300, connected to my main router using ethernet cable. I was able to setup guest wifi in Router mode, in addition to normal Wifi. All is working fine at this point.
But I want to use it only as a Wifi Access point, not as a Router (my main router allready has DHCP).
When I changed the network mode in the admin panel of the S1300, it erased the Guest Wifi.
I can log in to the admin panel, but now it only shows one wifi network (for each band, 2G/5G).
Is it possible to use it as Access Point and still have Guest Wifi ?
Is this a bug or by design ?
I’m planning to use it in Mesh mode in the future ( I have two s1300 device, currently only using one).
I’m running on latest firmware version 3.102 (testing).
Thanks.
