hello
i use several gl inet router for can do S2S.
i have one configured 1 AR750 like server at home.
by goudcloud i do the S2S connection only 2 router each time (for can access to machine 1 at time)
most of time is working well.
but for 3 machine i have problem.
i start the S2S, it start correctly.
i can ping the remote S2S ip adress
i can ping the remote lan ip adress of gl inet router
but i can’t ping the 2 machine that i have connect on remote lan ip, why?
this happen only on 3 different site. i have more tha 15 site working.
at home server is connect to 192.168.2.XXX
remote is connect to internet lan ip is 192.168.7.250 (i can ping it and acces on webpage)
machine 1 is connect 192.168.7.XXX not way to ping or connect
machine 2 is connect 192.168.7.XXX no way to ping or connect…
could you help me?
thanks
