S2S broken after config change
I was adding a new device in existing working S2S but it stuck on connectivity test even there was no changeto the main node.
  1. I did not stop s2s before updating
  2. During attempt to pass connectivity test old s2s was functional. Networks reachable
  3. There was no option to stop existing s2s anymore and I decided to delete it and recreate
  4. Deletion worked and old s2s stopped functioning but I still cannot create a new one. It fails instantly on connectivity test with when previously it was taking time
  5. Whe opening s2s edit it shows 3 warning
  • "Device version is less than 3.026 " lowest I have is 3.216
  • Subnode of mesh
  • Bridge mode
It feels like it's stuck in some bad state. How to fix it? Reboot of main node and some of othe nodes did not help
I am getting this same error with 2 x Brume2's.. Any advice?
My main node is also Brume2
We are aware of this issue and have urgently hot-fixed it. Please try again.
I'm still seeing the same problem (I think). After editing the enrolled devices, and clicking next to the port testing phase it does one of two things:
  1. Immediately goes to the S2S status screen but no data is ever sent. It selects a main node but will never connect after pressing start.
  2. It fails the test and says no ports are open on any router. Ports are open and I have two routers on different external IPs that do and have been set as main node before.
I just tried to unbind one of my nodes. Now I can't get it rebound to goodcloud because I have no record of the serial. Apparently dropbear is broken on this unit and is always requesting a RSA key as well. I'm unable to login and obtain the serial. @bruce Do you have historical record of previous bound devices if I supply ID and MAC?
Check this: Windows ssh stopped working with 3.x firmware
Interesting.. I was having same result from many other OS varieties too. The work around, worked. Thanks @admon
You can PM me the MAC and ID, and I will help you find the SN.
I got it, thanks @bruce
