I’ve only the main node what has a static IP, the other node does not has any.
So the connection is always initiated from the NODE1.
Restarting NODE1 brings up the S2S tunnel.
Stopping on goodcloud & restart it on the webpage brings up the tunnel
Executing manually via SSH the wireguard_watchdog does not bring up the tunnel
This happens when the internet-connection temporarely failed on Node1 or on the Main-Node
After reviewing the Configuration file /etc/config/gl_s2s we saw that on the NODE1 the
option endpoint xxx.xxx.xxx:xxxx
Setting was missing. After stopping and starting the Tunnel from goodcloud.xyz the option is restored.
So there may be some issue with the auto-provisioning on goodcloud.xyz
