Samba needs updating or a permanent solution. MT6000
This was fun trying to find a solution for the past hour to another problem that needs to be addressed in the next firmware update.
GL-MT6000 Firmware 4.6.8 op21
Mac computers, iPads, iPhones, do not see files on a hard drive that is attached to a router via USB port, when a hard drive is formatted as exFAT.
Files can be seen when a hard drive is directly attached to a Mac computer.
Here is a solution from a year ago, but has yet to be permanently implemented in to firmware.
To GL engineers, please add this solution as a permanent fix.
Cheers.
After another hour of trying to make this work, it partially works.
Im able to see the files on the hard drive but im only seeing about 1/4 of the total files on the drive.
Quick update;
I installed firmware 4.6.6 OP24 and the issue is not present. I didn't have to download any pluggins or make any additional configurations. Will this be resolved in OP21 firmware?
Thanks.
Merge to thread 50475:
