Hello. I am owner of device MUDI. Everything is ok except this.
At the beginning, screen shows correct information about connection but after some hours it start shows incorrect information both on the main tab and vpn tab
. Nothing has changed in settings during this photo.
How can I add more photo with beginning screen and vpn tab of course if it’s necessary?
If you turn off your VPN and LTE data connections, will it still be the same?
Is it possible for me to debug remotely?
I don’t try it but I don’t think that things are the root of the problem.
Yes. I can connect you via teamviewer for example.
Do you have an instant contact tool? Such as skype.
Unfortunately skype has been blocked in my network but we can contact via telegram for example or teamviewer
