Where could I find the ipkgs for screen and/or tmux that would install on GL-MT300N-V2?
Which version do you use for? The repo has tmux ipk on v2.27 or v3.0, you can install it directly.
root@GL-MT300N-V2:~# opkg install tmux
Unknown package ‘tmux’.
Collected errors:
- opkg_install_cmd: Cannot install package tmux.
I am on firmware 2.271
should you do a opkg update first?
opkg update
Right! My bad! Thanks! Now only need to somehow free some space for it to install ![]()
