[Script] Adblock primitive
For models like Opal, E750 etc that doesn't support Adguard home
Asked my friend to write really simple, setup and forget script. No settings, no nothing.
(Yes she allowed me to publish it here)
Script for geeks
#!/bin/sh
hosts_url="https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts"
hosts_file="/tmp/adblock-hosts"
update_script_path="/usr/bin/update_hosts.sh"
dnsmasq_conf="/etc/dnsmasq.conf"
if ! which wget >/dev/null 2>&1; then
  echo "wget is not installed. Installing..."
  opkg update
  opkg install wget
  if [ $? -ne 0 ]; then
    echo "Error installing wget. Please check your internet connection and try again."
    exit 1
  fi
  echo "wget installed successfully."
else
  echo "wget is already installed."
fi
cat <<EOF > "$update_script_path"
#!/bin/sh
wget -q -O "$hosts_file" "$hosts_url"
EOF
chmod +x "$update_script_path"
if ! grep -q "addn-hosts=$hosts_file" "$dnsmasq_conf"; then
  echo "addn-hosts=$hosts_file" >> "$dnsmasq_conf"
  /etc/init.d/dnsmasq restart
fi
(crontab -l 2>/dev/null; echo "@reboot $update_script_path"; echo "0 0 * * * $update_script_path") | crontab -
rm "/tmp/setup_hosts.sh"
echo "Hosts update setup complete and self-removal successful."
echo "The update script is located at: $update_script_path (persistent)"
echo "It will run on reboot and at midnight."
echo "Additional hosts file is saved in RAM at: $hosts_file"
echo "Dnsmasq configured to use it."
To run it just use this command:
sh <(wget -qO- https://pastebin.com/raw/jrT2JmpN)
Use the hosts to simply block some ads, without relying on plugins, it can indeed reduce the performance burden.
