I got inspired by this and this situation.
I wrote it for myself, but decided to share with community.
Here is is
#!/bin/sh
# Ultimate blocker installer for OpenWrt
# Date: 2025-10-30
echo "Ultimate blocker"
echo "This script will automatically install ad blocking hosts, block tracking and will attempt to block fake news/propaganda"
echo "NOT DESIGNED FOR ru REGION. Script blocks .ru and .su to avoid propaganda"
printf "Continue? (y/n) "
read ans
case "$ans" in
y|Y) ;;
*) echo "Aborted."; exit 0 ;;
esac
TMP_HOSTS="/tmp/ub_hosts.txt"
TARGET_HOSTS="/etc/hosts"
DNSMASQ_DIR="/etc/dnsmasq.conf.d"
DNSMASQ_FILE="${DNSMASQ_DIR}/ultimate-blocker.conf"
BACKUP_DIR="/etc/ultimate-blocker-backup-$(date +%s)"
# Ensure dnsmasq conf dir exists
mkdir -p "$DNSMASQ_DIR"
# Try primary download, fallback to mirror
rm -f "$TMP_HOSTS"
echo "Downloading hosts list..."
if ! curl -fsSL "https://raw.githubusercontent.com/StevenBlack/hosts/master/alternates/fakenews/hosts" -o "$TMP_HOSTS"; then
echo "Primary failed, trying mirror..."
if ! curl -fsSL "http://sbc.io/hosts/alternates/fakenews/hosts" -o "$TMP_HOSTS"; then
echo "Both downloads failed. Proceeding with local additions only."
rm -f "$TMP_HOSTS"
fi
fi
# Backup current hosts and dnsmasq conf if present
mkdir -p "$BACKUP_DIR"
cp -a "$TARGET_HOSTS" "$BACKUP_DIR/hosts.orig" 2>/dev/null || true
if [ -f "$DNSMASQ_FILE" ]; then
cp -a "$DNSMASQ_FILE" "$BACKUP_DIR/ultimate-blocker.conf.orig" 2>/dev/null || true
fi
TMP_ADD="/tmp/ub_additions.txt"
rm -f "$TMP_ADD"
touch "$TMP_ADD"
# If downloaded exist, sanitize it
if [ -s "$TMP_HOSTS" ]; then
# Syntax tweaks
awk '
/^[[:space:]]*#/ { next }
/^[[:space:]]*$/ { next }
# remove inline comments
gsub(/#.*/,"")
# trim
sub(/^[ \t]+/, "")
sub(/[ \t]+$/, "")
if ($1 ~ /^(0\.0\.0\.0|127\.0\.0\.1)$/ && $2 != "") {
print $1 " " $2
' "$TMP_HOSTS" >> "$TMP_ADD"
fi
# Add GL-iNet ad block
grep -q -F "ad-api.gl-inet.com" "$TARGET_HOSTS" 2>/dev/null || echo "0.0.0.0 ad-api.gl-inet.com" >> "$TMP_ADD"
grep -q -F "static.gl-inet.com" "$TARGET_HOSTS" 2>/dev/null || echo "0.0.0.0 static.gl-inet.com" >> "$TMP_ADD"
# Remove duplicates
if [ -s "$TMP_ADD" ]; then
# create a temp file
awk '
{ print }
' "$TARGET_HOSTS" 2>/dev/null > /tmp/ub_hosts_orig || true
# Append only lines not already present
while read -r line; do
[ -z "$line" ] && continue
# escape for grep
if ! grep -Fxq "$line" /tmp/ub_hosts_orig 2>/dev/null; then
echo "$line" >> /tmp/ub_hosts_orig
fi
done < "$TMP_ADD"
# Write merged hosts back
cp /tmp/ub_hosts_orig "$TARGET_HOSTS"
echo "Updated $TARGET_HOSTS"
fi
# Block ru propaganda
cat > "$DNSMASQ_FILE" <<'EOF'
address=/.ru/0.0.0.0
address=/.su/0.0.0.0
address=/.ru/::
address=/.su/::
EOF
# permissions :>
chmod 644 "$DNSMASQ_FILE" 2>/dev/null || true
# Restart dnsmasq
if /etc/init.d/dnsmasq status >/dev/null 2>&1; then
/etc/init.d/dnsmasq restart || {
echo "Warning: failed to restart dnsmasq. Try: /etc/init.d/dnsmasq restart"
else
# Try generic restart
if command -v systemctl >/dev/null 2>&1; then
systemctl restart dnsmasq || true
fi
fi
echo "Crap successfully blocked! Now you are more safe!"
# Self-remove script not to clutter your router
SELF="$(readlink -f "$0" 2>/dev/null || echo "$0")"
if [ -f "$SELF" ]; then
( sleep 1; rm -f "$SELF" ) &
fi
exit 0
It will be good for those who don't have Adguard home (ex E750v2) or don't use it to save some computing power.
If something, ping me i will try to fix script
