[script] Disable HTTP
Hi there :wave:
Wrote simple script to enable/disable port 80 on your router.
GitHub page
Version 2 :hugs:
#!/bin/bash
function process_action {
    echo "What would you like to do?"
    echo "Enter 'e' for enable port 80, 'd' for disable port 80, or 'r' for redirect from port 80 to 443."
    echo "Please note: Enter the option exactly as shown above."
    read action
    case $action in
        e|E)
            echo "Enabling HTTP access to the router"
            sed -i 's/#listen 80;/listen 80;/g' /etc/nginx/conf.d/gl.conf
            sed -i 's/#listen \[::\]:80;/listen \[::\]:80;/g' /etc/nginx/conf.d/gl.conf
        d|D)
            echo "Disabling HTTP access to the router"
            sed -i 's/listen 80;/#listen 80;/g' /etc/nginx/conf.d/gl.conf
            sed -i 's/listen \[::\]:80;/#listen \[::\]:80;/g' /etc/nginx/conf.d/gl.conf
        r|R)
            echo "WARNING: The redirect feature is untested and should be used at your own risk."
            read -p "Are you sure you want to proceed with setting up redirection from port 80 to 443? (y/n): " confirm
            if [[ $confirm =~ ^[Yy]$ ]]; then
                echo "Setting up redirection from port 80 to 443"
                if grep -q "return 301 https://\$host\$request_uri;" /etc/nginx/conf.d/gl.conf; then
                    cat <<EOF >> /etc/nginx/conf.d/gl.conf
server {
    listen 80 default_server;
    listen [::]:80 default_server;
    server_name _;
EOF
                else
                    echo "Redirection already set up."
                fi
            else
                echo "Redirect setup cancelled. Please choose another option."
                process_action
            fi
            echo "Invalid option. Please enter 'e', 'd', or 'r' exactly as shown above."
            process_action
    esac
    echo "Restarting nginx"
    /etc/init.d/nginx restart
    exit 0
process_action
Version 1
#!/bin/bash
echo "Do you want to enable or disable port 80?"
echo "Enter 'enable' to enable port 80 or 'disable' to disable port 80."
read action
if [ "$action" == "enable" ]; then
elif [ "$action" == "disable" ]; then
else
    echo "Invalid option. Please enter 'enable' or 'disable'."
    exit 1
fi
How to use it?
Run this commands on your host machine (NOT router):
nano port_config.sh
Paste code from above (or use v1 if you want) and save file.
scp -O -r port_config.sh root@192.168.8.1:/tmp
Enter password
ssh root@192.168.8.1
Enter password again
cd /tmp
./port_config.sh
DOUBLE CHECK THAT HTTPS SUPPORTED BEFORE RUNNING THE SCRIPT
Just replace http:// to https:// in link. If Admin page works, you can run the script. If not, use its option to enable http again.
Why block http (80), if you could redirect?
server {
    server_name _;
    return 301 https://$host$request_uri;
I think this will be more user-friendly.
We should keep in mind that there are devices without https.
If I remember right some older routers like mango and shadow don't use https.
Mostly, browsers block http or have HTTPS only mode (Firefox, Tor, Brave for example). So I think it is enough to just block.
But I modified script to include your idea :bulb:
Added instructions to how to check and use. Thanks!
If someone have any suggestions to improve, don’t hesitate to write!
GitHub instead of the forum would be nice :wink:
I am thinking about this as I wrote many scripts. Maybe, next one will be uploaded there :smile_cat:
UPD: @admon done :wink:
