As discussed here:
There is a way to setup different passwords to avoid using RADIUS server.
But setup looks extremely complicated, so this script will do everything automatically:
Script
#!/bin/sh
TEMP_DIRS="/tmp /var/tmp /dev/shm"
SCRIPT_DIR=$(dirname "$0")
IS_TEMP=0
for temp_dir in $TEMP_DIRS; do
if [ "$SCRIPT_DIR" = "$temp_dir" ]; then
IS_TEMP=1
break
fi
done
if [ $IS_TEMP -eq 0 ]; then
echo "This script must be run from a temporary directory."
echo "Please move it to a temporary directory and run it again."
exit 1
fi
trap 'rm -f "$0"' EXIT
opkg update
opkg install wpa_supplicant
echo "Enter the SSID:"
read SSID
echo "Enter the passphrases (separated by space):"
read -a PASSPHRASES
cat <<EOF >> /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
update_config=1
fast_reauth=1
ap_scan=1
EOF
for passphrase in "${PASSPHRASES[@]}"; do
network={
ssid="$SSID"
psk="$passphrase"
id_str="$passphrase"
key_mgmt=WPA-PSK
priority=1
EOF
done
cat <<EOF > /usr/local/bin/assign_permissions.sh
#!/bin/sh
CONNECTED_PASSPHRASE=\$(cat /etc/wpa_supplicant/wpa_supplicant.conf | grep -A 1 "id_str" | tail -n 1 | cut -d '"' -f 2)
case "\$CONNECTED_PASSPHRASE" in
"Passphrase1")
echo "Assigning permissions for Passphrase1"
"Passphrase2")
echo "Assigning permissions for Passphrase2"
echo "Unknown passphrase"
esac
EOF
chmod +x /usr/local/bin/assign_permissions.sh
echo "post-up=/usr/local/bin/assign_permissions.sh" >> /etc/wpa_supplicant/wpa_supplicant.conf
/etc/init.d/wpa_supplicant restart
