Hey!,
Today I decided to write a script for multipsk also since OpenWrt doesn't have a luci option yet and I also liked the way of using it in a form of a batch command.
here it is
#!/bin/sh
while getopts k:i:v:r:h flag
do
case "${flag}" in
k) key=${OPTARG};;
i) interface=${OPTARG};;
v) vid=${OPTARG};;
r) radio=${OPTARG};;
h)
echo "makepsk: command help"
echo "-k: wpa2 password"
echo "-i: interface/name where the vlan gets tagged to"
echo "-v: the tagged vid"
echo "-r: the defined radio"
exit 1
esac
done
if [ $OPTIND -eq 1 ];
then
echo "No options were passed."
exit 1
fi
echo "interface: $interface"
uci add wireless wifi-station
uci set wireless.@wifi-station[-1].vid="$vid"
uci set wireless.@wifi-station[-1].iface="$radio"
uci set wireless.@wifi-station[-1].key="$key"
uci add wireless wifi-vlan
uci set wireless.@wifi-vlan[-1].vid="$vid"
uci set wireless.@wifi-vlan[-1].name="$interface"
uci set wireless.@wifi-vlan[-1].network="$interface"
uci set wireless.@wifi-vlan[-1].iface="$radio"
uci commit wireless
to make it executable use chmod +x makepsk.sh
a command looks like:
./makepsk.sh -k "yourpassword" -i "aya" -v "90" -r "default_radio1"
this means clients with yourpassword gets redirected to interface aya the default_radio1 is either 5ghz or 2.4ghz you can check this inside the wireless config in /etc/config/wireless you have to restart wifi manually with the wifi command.
I decided to make this since this creates 2 uci nodes each time which can be confusing + there isn't much documentation than maybe only about wpa_psk_file on the OpenWrt wiki, you need to use WPA2 otherwise it will not work.
there is a chance this doesn't work, then your OpenWrt version might be too old and you have to resort to wpa_psk_file, but this should work on the latest MT3000/MT6000 OpenWrt 24 snapshots, so I thought why not post it ![]()
update 02-07-2024:
- add check against null arguments.
