Script: Update AdGuard Home
Thank you
Is it compatible with Brume 3 (MT-5000) ?
If there is AGH pre-installed, it should work.
Will you ever update Adguard Home with the next firmware version on the Flint 2? The current version is already out of date and I don't want to use this script.
From time to time there will be updates. If you want to use the most updated version, please use the script or update by yourself manually.
If I update it via the script, will I still see Adguard details from the GL GUI? or will it break?
You will still see details.
Sorry I’m lost I have a Flint 2 and the script works brilliant, I haven’t made it permanent maybe that’s what your asking
That script won't change your config.yaml, should be work and won't break GL UI
@admon I believe that the script no longer works with version 4.9.0 beta 2:
Try curl instead of wget.
@admon Similar:
That's an DNS issue on your side. Make sure that DNS works before running any command.
When I read the error message, I thought it might be something to do with the DNS, but browsing the internet – and therefore the resolving of internet addresses – works perfectly well.
Please check the DNS settings of your router. Since clients are able to use another DNS instead of your router it might not show issues there.
Disable VPN, AdGuard and other apps until you find the one that is the show stopper here.
I have disabled AdGuard Home (which is also causing problems on some devices on the IoT network) and the error message has changed slightly:
I don't have anything else running – no VPN or other apps
curl needs other parameters than wget :slight_smile:
I thought you know the commands, I am sorry for that! Try to usual wget way and it will work :slight_smile:
Yes, the script is now working properly :wink: , and no, I don’t know any Linux commands (I’m not very familiar with it as an operating system) :sweat_smile:
Now, I just need to figure out why AdGuard Home is causing me so many problems, which it didn’t do before...:thinking:
How much space is needed for this script?
I have a GL-X2000 and it only has about 20 MB left. As you may remember, the Tailscale update script caused storage issues for me, so I was just wondering.
Because there are a few exploits fixed in newer versions of AGH.
Thanks!
EDIT: Oh I see on the Github it requires 15 MB. Cutting it a little too close tbh.
Oh well, another disappointment with the GL-X2000
Did you ever get this done?
