Which device do you use?
Please re-run the script and post full output here.
Without enough space it will be difficult / impossible.
Why is there no space left? What did you do? ![]()
Nothing at all... Have AdGuard is the only extra-thing... i disable it but I can't update...
The real answer is... to dowgrade Do I have to reset factory or overwrite with Firmware Update image?
What happens if you use --restore as flag?
Phew. Broken because not enough space.
In that case, a full reset might be the fastest way to fix this.
The build process was optimized.
Minor versions (like the current 1.80.2) are now available as well.
-pre versions will be ignored.
Router reseted. Thank you for your help
Dear Admon,
Thanks for all your effort and support. I have used the script successfully and I am grateful to you.
I wanted to bring to your attention to a bug that I encountered today.
Today, I tried to use the script to update tailscale for a friend on Beryl AX. and I got an error message when the script tries to download the latest version of Tiny Tailscale. it says check your connection which I have verified is working.
after this I tried to check if i can reach the tiny URL inside the script
"TAILSCALE_TINY_URL="https://github.com/Admonstrator/glinet-tailscale-updater/releases/latest/download/"
After which I discovered that the previous link get redirected to the latest version 1.80.2 with 404 erorr page from GitHub.
https://github.com/Admonstrator/glinet-tailscale-updater/releases/download/v1.80.2
I believe the v1.80.2 is missing the amd64 files and all the rest of binaries except the source code.
to resolve the issue for my friend today, I have edited your script using vi tool and changed the tiny url to v1.80.0 which solved my issue.
again, Thanks for all of your hard work.
Regards,
Jadal
thanks, this bug is known right now and will be fixed soon.
The issue was fixed! ![]()
Script works as expected now, @Jadal
Works great for me (Linux GL-AXT1800 4.4.60 #0 SMP PREEMPT Sun Dec 15 15:18:01 2024 armv7l GNU/Linux)!
Thank you so much!
This script worked for me. Thank you, kindly!
Great script. Updated GL-X3000 perfectly from iPad using Termius. Couldn’t be easier. Thanks
Termius on the IPhone - 1 click update... great call.
Thx for the tip.
Thanks for the positive feedback, everyone! ![]()
Thanks for the script, working great!!
For some reason, after updating Tailscale it seems the UI bugs out. It starts saying Tailscale is in Beta and the options to unbind the device along with the account information aren't showing up. Slate ax
That's pretty weird indeed.
Maybe @bruce might be able to explain in what case the UI thinks it's beta or not?
