Yup, no issues.
You are using the wrong script. Please follow the steps in the first post of this thread.
did it thank you for your help @admon
Thank you for the script. It worked perfectly on my GL-A1300 to update the Tailscale version from 1.6.2 to 1.82.5
Came to this forum to thank you for the script, worked perfectly.
Maybe the update scripts ought to be pulled out of general threads and placed into a special update topic or linked on GL web pages. Wonder how hard it would be put these in gui?
I've did it several times remotely now. However, my remote routers are close enough that I could drive to them if something went wrong.
Thanks for trusting me and my script that often ![]()
Love the script and used it on my Brume 2. Just got my Comet KVM - have you tried the update Tailscale on a Comet using the script?
I don't own a comet yet, but you can simply try it, I would say.
After upgrading to version 1.1.1, you can use tailscale in the UI interface
I suggest that a gui feature to update things like tailscale and adguard be considered as part of gl-inet web admin panel maybe?
They already declined integrating it. Therefor nothing I could do here.
Ok thanks.
script fails on comet but it pretends not to. Can't read version file, find and edit starting script or properly compress config data but continues.
EDIT: it was actually updated but required a reboot.
Hi, amazingly helpfull stuff, thx!
Is it possible to make an installation permanent after it has already been installed?
regards
You could run --restore and then restart the script to make the installation permanent.
Or run those lines manually:
if grep -q "/root/tailscale_config_backup/" /etc/sysupgrade.conf; then
sed -i '/\/root\/tailscale_config_backup\//d' /etc/sysupgrade.conf
fi
if ! grep -q "/root/tailscale_config_backup/$TIMESTAMP.tar.gz" /etc/sysupgrade.conf; then
echo "/root/tailscale_config_backup/$TIMESTAMP.tar.gz" >>/etc/sysupgrade.conf
fi
if ! grep -q "/usr/sbin/tailscale" /etc/sysupgrade.conf; then
echo "/usr/sbin/tailscale" >>/etc/sysupgrade.conf
fi
if ! grep -q "/usr/sbin/tailscaled" /etc/sysupgrade.conf; then
echo "/usr/sbin/tailscaled" >>/etc/sysupgrade.conf
fi
if ! grep -q "/etc/config/tailscale" /etc/sysupgrade.conf; then
echo "/etc/config/tailscale" >>/etc/sysupgrade.conf
fi
fi
if ! grep -q "/usr/bin/gl_tailscale" /etc/sysupgrade.conf; then
echo "/usr/bin/gl_tailscale" >>/etc/sysupgrade.conf
fi
Could I also wait for a new tailscale version?
Totally, yep.
